Guys I'm going nuts here. I spent 2 and a half days doing the clutch, f'ing Bentley can kiss my ass. They never say remove the starter in the transmission removal. I did all work with basic tools in an underground garage on jackstands. And I've never replaced a clutch. so finally I started rotating the transmission to see if there is anything snagging it, and felt the starter bolts. Man what a pain to remove. Only problem is at this point it was like 5AM (didn't want to leave the car like this for a second longer than necessary because technically we're not allowed to do any work down there) and I didn't pull the battery cable. When removing the starter battery lead, it sparked against the connector, that made me get up and unplug the battery. And nothing electrical happened since then.
So I put everything back together about a half hr ago, all proud of myself that I have no bolts left over (almost freaked out that I bent the shifter links because the shifter was tilted forward, but then I tried rotating the lever in the ball, and that set it straight).
Lower the car etc, turn the key, fuel pump buzzes annnnd bupkus. Starter doesn't go, no click from the solenoid....
Guys please tell me I didn't fry the damn starter or solenoid?? Can they really be so sensitive...?!
All the connections look right. On the one by the engine block, there's only the small wire from the starter, on the other pin there's the battery lead and the other big lead whatever the hell that is. And the small wire on top of the panel is on too...
I tried reading through the Bentley for it but it says there's no fuse. But is there no relay or something else I can check if I fried? How can I check it? I'll go buy a multimeter tomorrow (moved to Vancouver from Toronto, didn't bring too many tools).
The thought of having to remove the starter makes me want to shoot myself. It was such an incredible pain to do during the clutch job and I had to rotate the transmission to get to the top bolt. If I have to replace the starter (please say I don't), is there a way to hold the %&(*&(# bolt from the inside of the engine bay?
