87 325IS hard start randomly
  • ParksMyCar
    • Apr 2016
    • 100
    When I crank my e30 it cranks for 3seconds then starts. Sometimes it will just crank and crank. I'll turn the key all the way off then crank it again and it will start. Normally when hot. Can repeat the issue seems to happen on when leaving public places lol. Possible fuel pump I'm thinking. Not sure. When accessory is on does the pump prime the fuel or only when cranking? Not familiar with the m20 fuel system.
    Please help really wanna sort the quirks out.
  • dnguyen1963
    • Nov 2011
    • 2649
    Do a smoke test when the engine is warm.
    • ParksMyCar
      • Apr 2016
      • 100
      Smoke test as in. Sorry not familiar
      • ParksMyCar
        • Apr 2016
        • 100
        The thing is it idles perfectly fine. Never once died. Just randomly hard starts
        • dnguyen1963
          • Nov 2011
          • 2649
          Smoke test is used to find vacuum leaks. When the engine is warm, metal expands causing vacuum leaks that you would not otherwise find when it is cold. This is a common problem with E30.
          • Kershaw
            • 11822
            Could be the ignition coil. Sometimes that just happens. Just stop cranking when you realize you're a few seconds past when it normally starts, turn the key back and then turn it on like you've been doing.
            You can go crazy chasing stupid stuff like that. And spend hundreds of dollars. And then not even fix it.
            AWD > RWD
            • TobyB
              • 5263
              Right, because it could be the main relay, the ignition switch...
              t
              • ParksMyCar
                • Apr 2016
                • 100
                Okay thanks guys. Just wish I could figure it out. And wish I could repeat the issue
