Fouled my plugs beyond black.
  • e30 gangsta
    • 3877
    Well i was driving my car and i noticed that it started sputtering ridiculously bad. So fast forward a bit i pull my plugs and out the're black and smell like pure gas. I fixed a nasty vac leak and now my car is running ridiculously rich. I would like to know 3 things.
    1. Which way do i turn the wheel on my afm to make the mixture leaner?
    2. Will the fuel pressure regulator make the car run rich if it is faulty?
    3. I Will be borrowing a wideband tomorrow. And i would like to know what afr do most NA m20's run @ so that i can retune the afm. Thanks again.
  • 808BMW
    • 2910
    I'd guess 14.7 on the afr's
    • e30 gangsta
      • 3877
      anyone else?
      • digger
        • Nov 2005
        • 6171
        14.7 at light load (it has an O2 sensor afterall) and probably around 13 at WOT
        • 325ise30
          • May 2005
          • 61
          99% sure its the FPR, ive saw quite a few due this and it be a failed fpr. Get a fuel preasure tester, check the bently specs, and don't mess with the afm.
          Previous cars, bmw's 85 325e 93 318is
          88 suzuki samurai
          • X2theZ3
            • Mar 2004
            • 932
            what mods do you have?
            Why not try unplugging the batter to reset the ecu?
            • e30 gangsta
              • 3877
              Mark d 93 octane chip
              S50 injectors
              M30 afm
              Nothing crazy just had the afm tuned with a vac leak then once I fixed it car started running rediculosy rich. :(
              • chuckybob
                • Aug 2004
                • 952
                before you fuck with the afm, try resetting your ecu. it might have been compensating for the vacuum leak.
                : : 1984 318i : : PNW E30 Crew : : Sold!!
                Now becoming the R3vlimited Pro3 car
                http://www.r3vlimited.com/board/showthread.php?t=93780
                • e30 gangsta
                  • 3877
                  Good idea thanks.
                  • e30 gangsta
                    • 3877
                    Ok got the handheled lc1. I was thinking just to install it in the o2 sensor bung a get a reading. But the handled won't send a o2 signal to my ecu. Will that affect the reading/ performance?
                    • Vedubin01
                      • Jun 2006
                      • 5852
                      Yes it would send the ECU into limp mode and run full rich. Its a safty function so you will not lose the engine.
                      BTW you get your belt fixed?
                      • e30 gangsta
                        • 3877
                        Yes i did, friend showed up with the belt and we changed it right there with the bmw trunk tools. Ill be wrenching on the e30 in a bit. Thanks for asking.
