E30 Noise
  • Idrisu
    • Jul 2015
    • 173
    E30 Noise
    Been having issues with my E30. Whenever I start the car I hear this siphoning like sound coming from the passenger side of the tank. You can sort hear it on the drivers side. About 2 minutes into idling, the sound stops and the engine cuts off. Not sure if it could be the fuel pump or the fuel pressure regulator. I know both my level senders are bad.
  • dishwab
    • Mar 2012
    • 681
    Probably your fuel pump dying. In an E30 the fuel pump is accessed by removing the back seat and pulling it out of the tank on the passenger side of the rear bench. Pretty easy to replace
    • Idrisu
      • Jul 2015
      • 173
      would the level senders play apart in the noise?
      • TobyB
        • 5280
        Other than being in the same physical location, not much...
        t
        • itsonlygeorge
          • Feb 2014
          • 852
          You're fuel level senders are probably ok. It's just a float and a switch really. I would start by taking the pump out to take a look at it and shine a flash light in the tank to look for rust and crud on the bottom of the tank. Rust = Bad.
          It is most likely your fuel pump. Order a new one stick it in there and fire the car up. If there is rust in the tank your best bet will be to get a new tank as it will only be a matter of time before the new pump gets burnt up if the filter gets clogged.
          1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
          Originally posted by nando
          I don't think there's really strong evidence that ZDDP harms cats.
