So...my car's a boat.
  • Sean
    • 5793
    I bet 6 4" is a bit tight in the car, eh?
    Really - the boards are that much heavier? It'll be interesting to found out soon ehre! :)
    - Sean Hayes
    • chuckybob
      • Aug 2004
      • 952
      is that a cf hood you have? if not, upgrading to one will save you 20 lbs, upgrading to a fiberglass pinned on one will save you 38. taking out the backseats saves probably 30. search for the e30 weight loss guide, there's a ton of weight that can be removed. there was one guy on here who ran a ~2000lb rally 325i, stripped everything but the lights and the side fenders, and replaced everything else with lighter weight aftermarket or euro parts. aftermarket wheels can save you a lot too.
      : : 1984 318i : : PNW E30 Crew : : Sold!!
      Now becoming the R3vlimited Pro3 car
      http://www.r3vlimited.com/board/showthread.php?t=93780
      • AdironRider
        • Dec 2004
        • 3491
        Hood pins are the coolest.
        Back to my roots
        • Sean
          • 5793
          If I got pins instead of using the current latch system, that would save weight too, RIGHT?!
          OMG THATS HOT! :D :giggle:
          I guess part of me wants to lose weight, but this is my only car, my daily driver, my road trip car, my track car...everything. So, really, I want to remove the stuff that I can put back in - and will remain in most of the time. But I think I may just pull the tar, and then when autocrossing or going to driving schools, I'll yank the seats and other stuff. But, unfortunately...I just can't justify the cost of a CF or fiberglass hood.
          I could just do the no hood mod and call it good. As seen below. :)
          - Sean Hayes
            • 34844
            yeah, because it's totally cool to drive a stripped down "track" beater on the street.
            • ddavidv
              • 344
              Trunk tar is 40 lbs, but you're kind of removing weight where you may actually want it.
              Factory seats are really heavy. Race seats solve that, but aren't really comfortable for daily use.
              Glass is really heavy. Replace you side and rear glass with Plexi. :)
              There is a lot of weight that can be removed on these, but do you really want to live with a noisy, vibrating, no-padding seat, no a/c kind of car?
              • Sean
                • 5793
                well, no ac is fine - and its gone. But I don't mind the noise - it's already noisy. Nothing vibrates.
                However - I want my car to look comfrortable inside and be comfortable. So...yea. I'll do what I can do - but I may just leave it.
                - Sean Hayes
                • chuckybob
                  • Aug 2004
                  • 952
                  youre right, all the "cool kids" are doing $10k OEM restorations for worse performance
                  • ldsbeaker
                    • Aug 2004
                    • 3098
                    [QUOTE=Sean]I bet 6 4" is a bit tight in the car, eh?[QUOTE]
                    I don't think that I would be able to do a track day or anything that required a helmet... but I hope to someday find a way to have lower seats. Hints?
                    Slicktop City!
                    • xLibelle
                      • Aug 2004
                      • 2673
                      diving boards are heavy too, swap to plastics. I think it's about a 25lbs difference.
                      I'm curious what my car weighs... it never had trunk tar or anything like that though.
                      i'm sorry, but dont tell people this unless you have proof!
                      i have weighed both ENTIRE sets and aluminum bumper setup's are just under 5lbs LESS than plastics!
                      • sticksdaman
                        • Apr 2005
                        • 2987
                        yea i kinda felt that way too about the plastics but the ballast inside the plastic bumpers can be removed but at the cost of saftey is it really worth it?... i feel they weigh about the same and if there is any difference its negligable
                        Originally posted by ebelements
                        Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                        • chuckybob
                          • Aug 2004
                          • 952
                          BUT THEY LOOK BETTER! that makes them infinitely better :roll:
                          • xLibelle
                            • Aug 2004
                            • 2673
                            nothing can be removed. /thread jack
                              • 34844
                              basically, yes.
                              point taken on the weight, should check the ones out on my parts car to see for myself.
                                • 34844
                                yeah, because it totally matters how fast your car is on the street. :roll:
