AC line running to FPR?
  • cleavon
    • Mar 2014
    • 2
    The car is an 87 325e with a later model i engine. I didn't do the swap so I'm unsure of what was actually done.
    Next to the passenger side shock tower there is a canister in the line thats coming from the compressor into the evaporator. The canister is part of the line(no fittings on either end) and it has two lines coming out of the top of it that run along the top of the firewall to the drivers side. One connects to the back of the fuel pressure regulator and the other runs underneath the car to the rear. Any ideas as to what's going on here?
  • 101
    • Jul 2011
    • 764
    That's the rare and highly sought after fuel cooler option. :)
    Apparently this was installed on a few of the later 86 and early 87 production cars and was designed to route the return fuel through the air conditioning circuit to cool it before returning it to the tank. Think heat exchanger.
    You can safely bypass all that crap and remove it from the car if you want. Then route the return fuel line directly from the fuel rail to the metal return line under the car. There's less chance for leakage with the extra lengths of hose and joints removed.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • cleavon
      • Mar 2014
      • 2
      I guess I can can look forward to some performance gains if I get the ac working..
      Thanks for the info
      • roguetoaster
        Biggus Tippus
        • 7830
        Wow, that's a hilarious and idiotic system that I was unaware of previously. Right up there with the zyklon (cyclone) separator in air boxes, albeit for different reasons.
        • ELVA164
          • 4861
          Can you post some pictures of the setup for posterity?
          • 101
            • Jul 2011
            • 764
            OP will need to do that. I've tossed the remnants already.
            Here's the diagram off RealOEM ...
            http://www.realoem.com/bmw/enUS/show...diagId=16_0301
            101
            The E30 collection:
            • TobyB
              • 5280
              Wasn't it a quick and dirty fix for high temps and high altitudes? Fuel vaporization would
              cause the car to lose power/ quit altogether.
              One Pro3'er used it as a loophole to put a fuel cooler on...
              t
              • jeffnhiscars
                • Jun 2011
                • 6011
                For those of us who remember carbs, they were very susceptible to vapor lock. I think the higher operating pressures of FI reduced that a lot but obviously bmw felt obliged to create a system that, in theory, would prevent it.
                Alice the Time Capsule
