Battery light/alternator instrument gauge
  • kchase731
    • May 2016
    • 47
    Just an FYI for everyone. I got this resolved. I called the guy that I bought the rebuilt alternator from, all they do is alternators. He said the reason so many people have issues on e30s is they have rubber bushings where they mount to the car and it often doesn't ground correctly because it's not making a solid enough ground at the connection. The alternator I purchased has an external ground terminal. So a $5 grounding cable to the chassis from the alternator fixed the issue right away.
    If anyone else has these issues I guess check to see if you can adjust the alternator at the mounts to make sure it grounds completely. The alternator I pulled off the car was a aftermarket and it certainly didn't have an external ground. The new one I bought does and that's all it took
    • reelizmpro
      • 9518
      Have you checked the wiring harness to the alternator? You got the correct alternator with solid mounts right? Assuming you have a 325i. Take a pic of the alternator.
      Then they sold u the wrong alternator. 325's came with solid mounts and don't require a separate ground wire like the 318i and M3 which are isolated by rubber mounts.
      88 M3 - LACHSSILBER/SCHWARZE
      • kchase731
        • May 2016
        • 47
        Thanks.
        Yeah all makes sense now. I appreciate everyone's help
