How to seal
  • ParksMyCar
    • Apr 2016
    • 100
    How to seal
    How do I seal the metal to metal hose for the idle control module that is splined into the intake manifold. Please let me know
  • vpilarrt
    • Jun 2006
    • 2096
    I've used JB Weld
    • ParksMyCar
      • Apr 2016
      • 100
      Huh how did it hold. I've heard some people use wood glue. It's really messing with my idle. I'm surprised bmw used such a bad design
      • jeffnhiscars
        • Jun 2011
        • 6011
        There's a DIY to tap those and use screw in fittings. One and done
        Alice the Time Capsule
        • ParksMyCar
          • Apr 2016
          • 100
          What is it called
          • jeffnhiscars
            • Jun 2011
            • 6011
            What is what called...the DIY to fix the throttle body leak ?
            Look in the....DIY section
            • AndrewBird
              The Mad Scientist
              • 11898
              I'd avoid epoxy/jb weld in case you need to remove them later. Gasket maker/sealer will work fine and allow removal later.
              • Kershaw
                • 11822
                I got tired of gasket RTV (red stuff) failing and went with adhesive RTV (clear/white stuff) and it's held great.
                AWD > RWD
                • ecsk
                  • Nov 2011
                  • 106
                  You don't need to use strong glue or whatever for that join. Quite often it needs to come out when ICV is removed for cleaning. I used RTV sealant, it has no trouble so far.
                  • ParksMyCar
                    • Apr 2016
                    • 100
                    Well I ended in just jb welding it. I'll probably tap it when my intake comes off for paint next summer. The idle is better but still a little lumpy. I've never heard an e30 before let alone a m20 so I'm assuming a little lumpy is ok. I'm going to replace the fuel filter and possibly pump soon just to make sure. Theirs a little lag when hitting the throttle in neutral
