Reverse lights not working
  • M_3_X
    • Jul 2016
    • 162
    New to me 1991 325ic manual. So I replaced the reverse lights switch due to both not working at all, fuses are all good bulbs are good. Still no lights.
    Where to start tracking it down?
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    ___________________
    River City Bimmers BMW CCA
    2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
    2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
    1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
  • reelizmpro
    • 9558
    Check the switch and wiring. The wiring runs up the shifter and connects by the boot inside the car. The switch is on the drivers side of the trans.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • M_3_X
      • Jul 2016
      • 162
      I already replaced the switch with a new one. So where exactly inside the boot does the wiring connect to?
      -Mario Andretti.
      ___________________
      • wilholl
        • May 2012
        • 518
        should be a connector inside the center console underneath the shifter boot.
        The wires from the reverse switch run up through the rubber grommet to this connector.
        1988 325 non-letter Seta "Bronzit"
        1991 325ic "Laguna Green" (Sold)
        1993 325i "Laguna Green/Silver" (Sold)
        1998 528i "Artic Silver" m-sport(totalled by drunk driver)
        2000 528i Titansilber/gray m-sport
        2000 528i Titansilber/black m-sport(sold)
        2001 525i Anthracite m-sport(sold)
        2013 750i Black/Black m-sport "Beast"
        • Todd Black 88
          • Oct 2007
          • 3449
          Easiest thing to do is pull the shift boot, and you will see a pair of wires that run through the rubber shifter bushing, under the car. There will be a connector right there under the shift boot.
          Disconnect the wiring at the plug and jumper the wires that come from the console area. If the lights come on (when the car is on) then the issue is with the wiring under the car or the switch or tranny itself. If it doesn't come on its the wiring, fuse, etc in the car.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • M_3_X
            • Jul 2016
            • 162
            Thanks guys, I've narrowed it down to the wiring from the connector inside the boot down to the switch. Lights came ON when I jumped the wires and the switch is new.
            Anyone have the part number for that harness?
            -Mario Andretti.
            ___________________
            • Todd Black 88
              • Oct 2007
              • 3449
              Where did you jumper the wires? The boot?
              Jumper it at the switch and test.
              Search my name for my issue with a new bmw switch being shorter then the original.
              2010 F650gs twin
              • M_3_X
                • Jul 2016
                • 162
                Yes, at the boot. I will re-test at the switch.
                -Mario Andretti.
                ___________________
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  2010 F650gs twin
                  • itsonlygeorge
                    • Feb 2014
                    • 852
                    I redid the harness using a bit of weather proof shielded security wire and used a spare connector for the end. My old switch still works, it was just the wire.
                    1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
                    Originally posted by nando
                    I don't think there's really strong evidence that ZDDP harms cats.
                    • uturn
                      • Dec 2010
                      • 1008
                      I've installed the switch with a crush washer and found it won't work. Had to remove it and is install as is.
                      • c0rbin9
                        • Dec 2015
                        • 609
                        Just diagnosed this on my car as a problem with the switch or switch wiring (probably wiring like everyone else) by bypassing the switch as Todd recommended. Will solder this weekend. Seems like a common failure point.
                        1991 318is Brillantrot daily driver (slow restoration)
                        • M_3_X
                          • Jul 2016
                          • 162
                          Have reverse lights!
                          Well, finally got my ass to do this project. Installed a new wiring harness and problem solved. Threading the harness through the rubber boot at the bottom of the shifter was a bitch, other than than very straight forward.
                          Thanks all for their input!
                          -Mario Andretti.
                          ___________________
