Which A/C Compressor?
  • The Dark Side of Will
    • Jun 2010
    • 2796
    My A/C compressor in 11/87 325iX is shot.
    I will not be doing the full R134 conversion at this time. (That will come later when I do my planned engine swap).
    For 1987, RockAuto lists the following compressor kits (including accumulator/receiver/dryer):
    Denso 10P15E for $291
    Seiko Seiki 148DW7 for $344
    Bosch for $349
    For '88, Rock adds:
    Denso 10PA17C for $259
    All of the above from 4 seasons and available with or without a "black terminal" on the pressure switch.
    (There's also a "10PA17C style" compressor from an outfit called GPD for less than $200 for the kit, but that scares me).
    I don't want to spend $350 for the compressor... So between the Denso 10PA17C and 10P15E, which one should I get? What are the differences between the two? I haven't come up with much online.
  • uturn
    • Dec 2010
    • 1005
    The hose fittings are different on the Denso vs seiko/bosch/behr compressor. 10p15 is what our e30's came with (those that got the Denso compressors). I believe the 10pa17 came on the m5x engines... Online pictures show it to have the 4 holes that mount it to the block. My 4 seasons a/c compressor lasted that long, 4 seasons... it grenaded after just a year of use.
    10p15... you adjust the compressor to take up slack on the belt.
    10pa17... compressor is mounted solid to the engine and belt tension is taken care of by an idle pulley.
    • Das Delfin
      • Sep 2014
      • 2293
      you have to figure out what you have in there now and then buy the replacement for that. The hoses are different from Denso than they are for the Bosch. So unless you also want to pay for a new hose, buy the compressor that is a direct match for wha tyou already have.
      Rockauto typically has the best prices but keep in mind that if it's a Four Seasons, it comes preloaded with PAG oil, which is not compatible with R12.
      There is a company that rebuilds compressors based in Texas. It comes to around $200 after shipping. There's a link to them somewhere in one of the A/C threads I made
      • jeffnhiscars
        • Jun 2011
        • 6011
        A new r134 compressor is $200...food for thought
        Alice the Time Capsule
          • Jun 2010
          • 2796
          I went back and snapped some pics of the unit.
          I saw the Behr part number while the Bosch was still covered in scunge. I was looking at the options on Rock thinking "I guess the Behr unit isn't available anymore". Ooops.
          So because I have a Bosch, I have to replace it with a Bosch unless I replace the hose as well (which one? Both?) In looking at the photos on Rock more closely, I see that the Bosch is the exact match for the one I have.
          I plan to use a drop-in R12 replacement that isn't R12. It claims to be compatible with either mineral oil or PAG oil.
          The TX rebuilder at $200 sounds like a good deal. Do you remember the name of the company right off?
          ECS has the hoses for $90 for the one and $100 for the other. Feh.
          I did find this post about which compressors are not ok with R134:
          Originally posted by jeffnhiscars
          Production dates and models with compressors from the factory that ARE NOT r134 compatible:
          E30
          318i 7/85-8/85
          325e, 325i, 325iC 7/87-10/88
          325iX, M3 all
          Bosch compressors that are also NOT r134 compatible:
          64 52 1 377 940
          941
          943
          944
          946
          947
          64 52 1 385 416
          930
          64 52 1 386 411
          None of those compressors is mine, but my car falls under "325iX All" rather easily.
          • jeffnhiscars
            • Jun 2011
            • 6011
            The compatibility concern is with the seals and I suspect a rebuild will have updated (i.e. R134 compatible) seals. I do have to say again though, for what you ar contemplating spending,,I'd look at a proper conversion with a proper r134 compressor.
            Despite all the nay sayers my conversion gave me 50 at th vents yesterday when it was 95 outside.
            • tomstin
              • Mar 2015
              • 569
              I'm struggling with the R134 compressor decision. I've been collection the parts to rebuild by AC system. From what research I've done it appears I had a Denso installed originally but now there is a Sanden installed.
              I had replacement hoses made up so the hose fitment is a concern.
              As heavy as these compressor are, I don't want to order the wrong one and have to ship it back (already had a situation on cores where the shipping cost almost made the core return cost prohibitive).
              I'm concerned about the quality of the 4seasons, any suggestion on better brands?
              2004 525i Manual - 1985 325E Coupe Manual
              • nrubenstein
                • 3148
                If you've already got a Sanden, there's no reason not to stick with it.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • g.ruff561
                  • 1267
                  There is also a very good AC compressor rebuild shop in Ft. Lauderdale, FL. called Polar Bear. Gretchen, the wife answers the phone and has auto ac knowledge. But her husband Joe is the man. They have reasonable rates and will give you info over the phone. They rebuilt my DD compressor 5 years ago. I refer local E30 peeps to him all the time. Not even a hiccup.
                  Contact number is 954-463-6610. Give them a call. Good Luck............ G.
                  • Caperix
                    • Feb 2018
                    • 194
                    Sorry to dig this thread back up,
                    I have a 91 325i that the compressor is leaking out the front seal. The compressor installed is a SS-811 PB3. The replacement compressors are for a SS-148DW7 & may require replacement of the suction hose. Does anyone know if there are compadability issues between the 2 seiko compressors?
