Hi everyone,
So it's time for a fairly major...freshening for the E30 and I've collected a list of parts. I'm going to replace the clutch, reseal the gearbox, update/improve the shifter, and change the rear main seal. I won't be doing this work myself so I want to make sure I have all the parts right off the bat. If you see anything missing or incorrect, please let me know!
Clutch
Genuine BMW clutch fork spring, PN 21511204327
FTE hose, master to slave cylinder, PN 21521156673
Fichtel-Sachs clutch kit (pressure plate, clutch disk, TOB), PN KF29603
FTE clutch master cylinder, PN 21521156000
SKF pilot bearing, PN11211709934
Genuine BMW Pressure Plate Bolt, PN 07119919939 (x6)
FTE clutch slave cylinder, PN 21521157212
Metal clutch pivot pin, PN 21511202659
Gearbox
CRP Gearbox mount, PN 23711131664 (x2)
Corteco input shaft seal, PN 23121209311
Victor Reinz output shaft seal, PN 23121205340
Shifter
Garagistic delrin shifter bushing kit (includes PN 25117519669, 25111469397, 25111220707, 25111221849)
E60 Genuine BMW shift lever, PN 25117546373
Garagistic DSSR
Misc.
Victor Reinz exhaust manifold gasket, PN 11761711717 (x2)
SKF rear main seal, PN 11142249533
Copper exhaust nuts, PN 18301737774 (x6)
I think I need another rubber mount for the shifter, but I'm having a hard time figuring out which one it is. I think it's a rear carrier bushing?
Thanks again,
Mike
Clutch
Gearbox
Shifter
Garagistic DSSR
Misc.
Thanks again,
Mike
