BavAuto Strut bar Fitment
  • sampayne
    • Apr 2014
    • 396
    I acquired a bavauto strut brace a little while ago and I'm having some issues getting it to fit. The bar is about 3/4" off from fitting. I've tried jacking up the subframe to let the shock towers settle but, that didn't seem to give much, although I did not let it settle for too long. I've read other threads about troubles with strut braces, but none that I've seen have given any real advice besides using a big hammer to persuade it haha. This brace is pretty stiff with the double bars going across, so it really doesn't have too much flex. Not sure if anyone else with a bavauto brace like this has had issues, but any tips or ideas would be appreciated. Thanks
    Originally posted by 2mAn
    The BMW V6 is the best
  • ba114
    • Sep 2015
    • 364
    i dont know if its just me, but that looks like its off by a VERY long way
    RHD OBD2 M50b25 turbo build thread:
    http://www.r3vlimited.com/board/showthread.php?t=384800
    • ak-
      • 12422
      IE notes this before buying a bar - something to research I suppose
      1991 325iS turbo
      • SkiFree
        • Jun 2011
        • 2766
        ^I wrote that, and have proven it first hand on many occasions. Makes for some entertainment at meets. (how different each car in a row really is). Also used to make for great entertainment on the phone.
        "Yeah, your bar doesn't fit. You suck, you should really check the brace before sending it out. I'm sending it back and buying a uuc/sparco/garagfantastic/etc."
        "Dearest gentleman, did you read the complete listing prior to ordering?"
        ....fast forward two weeks later, either a thread complaining about the second bar pops up, or it quietly sells on ebay.
        If the car is just too off to make the bar fit, then you are left with two choices.
        1) Return the bar (politely explaining the problem)
        2) Break out the hack-saw and welder, section the bar, weld, and slap it on.
        ADAMS Autosport
        • sampayne
          • Apr 2014
          • 396
          Yeah, its pretty bad, but the pictures definitely makes it look more dramatic. If its properly aligned with the bolt holes it looks way better.
          I got the bar second hand, so returning it is not an option. However, I picked it up for pretty cheap so I'm not afraid to chop it up and weld it. I'll probably give that a try if nothing else works.
          Thanks for the responses!
          • AndrewBird
            The Mad Scientist
            • 11897
            Someone should make a bar with a bolt together flange in the middle and a set of shims to space the bar apart to accommodate different widths. Then just make it a bit undersized the factory spec and use shims accordingly. Problem solved.
            • SkiFree
              • Jun 2011
              • 2766
              Absolutely.
              ADAMS Autosport
              • sampayne
                • Apr 2014
                • 396
                Brilliant
                • Kershaw
                  • 11822
                  Several companies do.
                  AWD > RWD
                  • ak-
                    • 12422
                    The strut bar I'm using (can't remember the maker), has an eccentric bolt on each end of the tower that you can tighten/loosen to make the 3-bolt plates "push" the towers out.
                    Thought it was neat
                    1991 325iS turbo
                    • Todd Black 88
                      • Oct 2007
                      • 3449
                      I took an RD bar, removed the bolts mounting the bar to the plates, mounted the plates, slid the bar into place on the plates and red riled the holes.
                      I then removed the entire thing and cut away the old holes and shaped the plates like it was. Looks factory and fits my chassis perfect.
                      Here you can see the bolt holes added.
                      And here after trimming.
                      Originally posted by codyep3
                      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                      2001 silver/Blk 325 cabby. SOLD
                      2002 325xit Sil/blk. SOLD
                      2010 F650gs twin
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        Problem I see with bolt together strut bars is wouldn't you lose the stiffness your trying to gain by adding the bolts? Would it not allow the bar to flex at those points therefore loosing any rigidity you just tried to gain. Id want a solid bar so that there can be zero flex.
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                        • jpod999
                          • Dec 2015
                          • 1401
                          I built a strut tower bar with a friend who is in residential fabrication a number of years ago. He told me exactly what you just said, adding hardware decreases the rigidity- so we built a solid bar. Unfortunately it doesn't work with the BC camber plates so I had to pull it off.
                          OBDI M62B44/6 swap
                          Transaction feedback
                          - jpod999
                          • SkiFree
                            • Jun 2011
                            • 2766
                            Yes, it'll lose a bit of rigidity. However, what percent is determined by the bar's design. Could be %5 or %15.
                            Don't lose site the fact that even at a reduced rigidity, it is far better than not running anything (because the solid bar won't fit).
                            ADAMS Autosport
                            • M3Eater
                              • Dec 2010
                              • 7
                              Sampayne - We (BavAuto) have historically had problems with E30 stressbar fitment, due to chassis tweaking. At one point, I took a bar out and test fit it to 6 different E30s that we had on the lot. Of these, only one was a perfect fit. Two could be persuaded to go on. Of the other three, one might have been persuaded if the car was lifted and allowed to hang (as you described), but we didn't bother with it in this test. One was 3/4" off and one was a full inch off.
