No Power or Partial Power In The Cabin
  • BuzzBomb
    • Feb 2012
    • 89
    Hello all,
    I took on an '85 e30 project that has some weird things going on electrically.
    The engine harness is fine, no problems there. The cluster seems to have partial power, the gas gauge, temp gauge, and the brake warning lamp work sporadically. There is no or partial voltage at the green/red "always hot" wire to the radio. The digital clock lights uo at key on but randomly has no readout.
    The thing is, the fan switch works, hazard and defrost buttons work. I'm thinking that there is a problem with the harness either as it enters the cabin through the firewall or in the fusebox. Everything points to a missing/loose ground, but that wouldn't explain the lack of voltage to things. I know the dash was recently changed. Is there somewhere to check to see if it's a loose connection under the dash?
    '88 e28 B9
    '74 e12 525
  • TobyB
    • 5297
    will help...
    t
    • BuzzBomb
      • Feb 2012
      • 89
      Is there a source of diagrams for a euro market cars? This is a 323i, and I think there might be a few differences from a US market car.
      Sent from my iPad using Tapatalk
      '88 e28 B9
      '74 e12 525
      • tomstin
        • Mar 2015
        • 570
        Originally posted by BuzzBomb
        Hello all,
        I'm fighting with a similar problem, comes and goes. The strange part, when the cluster is partially out, along with the radio, if I turn on the windshield wipers on, everything comes back.
        Recently, it appears something involved in this mess must have stayed hot. Battery was dead, pulled the battery cable, charged the battery, everything seems fine...for now.
        Something strange going on!
        2004 525i Manual - 1985 325E Coupe Manual
