Late Model Kick Panel Mounting Hardware???
  • mmoyer11
    • May 2015
    • 205
    Looking for some info on what hardware is needed to mount the trim panel on a late model 325i coupe (90'). Everything I have read says that with the switch to late model the coupes went from the trim panel push pin PN: 51451916579 to a 8mm bolt/10mm fastener combination?
    Does anybody have more info on what exactly is needed? Don't want to spend hours at the hardware store trying to make stuff fit.
    Much appreciated.
  • reelizmpro
    • 9552
    The 2pc air bag panel uses 4 8mm bolts that secure the 2 halves on the bottom and 3 screws that secure the panel on top.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • mmoyer11
      • May 2015
      • 205
      Thank you!
