Brake pad light wiring
  • Mook613
    • Apr 2016
    • 232
    My brake lining light is on.
    The sensors looked okay (plastic is all in-tact), but I replaced them anyways... light still on.
    Had a cut wire for the wiring in the driver's wheel well, and I had that fixed by soldering in new wires... light still on.
    Tried shorting the wiring by placing a wire into the connectors... light still on.
    For now I have pulled the lightbulb out of the cluster, but I'd like to figure this one out.
    How would I go about tracing the brake lining wires and find out where the short is?
  • uturn
    • Dec 2010
    • 998
    Front and back sensors I believe are tied in series. Have you checked the rear passenger's side sensor?
    • Maddog
      • Dec 2006
      • 112
      If it's not the pad wear sensors, it's a broken solder on you instrument board. There is a post showing the location and a fix.
      • Mook613
        • Apr 2016
        • 232
        Thanks, I just looked that up and will have to check out the connections with the 220ohm resistor tomorrow.
