Am I insane? Thoughts on E30 total restoration. PLEASE HELP.
  • BHT2109
    • Sep 2016
    • 68
    Greetings! Newb here; don't even own an E30 (YET!).
    I need your thoughts regarding a near-total E30 restoration. The goal is to start with a “shell”, replace/repair all major systems, and end up with a vehicle that - in many respects - can be considered “new”. I realize that this is the goal of many restorations, but I actually want to make it happen.
    Please refer to restoration outline below.
    What I need from the E30 community is general advice and opinions, and to basically answer these three questions:
    1. Has anyone successfully attempted what I’m planning to do (below)? What were your experiences? Are you happy with the results?
    2. I want to basically end up with a 325iS. Can the work outlined below be installed on a 318 or 325e shell? What special considerations would I need to address in upgrading a 318 shell, for instance?
    3. Once completed, could I consider this a “new” E30? Will I be able to crank out 300,000 miles from my work? (Let’s assume that I daily-drive it very conservatively: 15,000mi/year, all fluids religiously changed, garaged, no snow, all scheduled preventative maintenance performed, etc). Basically, it’d be an oft-used garage queen. I would want this car to outlast me (never to be sold).
    RESTORATION OUTLINE
    Budget: $15,000
    Rebuilt M20B25 (325i) Engine: $3,500 (complete top and bottom teardown; includes labor)
    Rebuilt Getrag 260 Transmission: $1,700 (complete teardown; includes labor)
    Remanufactured driveshaft: $500
    Suspension Rebuild Kit: $1,363 (shocks/springs, end links, bushings, etc)
    Control Arms: $200
    Limited Slip Diff: $1,400 (purchase used + parts & rebuild/installation labor)
    Brake Overhaul Kit: $480 (4 discs, caliper rebuilds, pads, steel brake lines, etc)
    Flex disc kit: $82
    Tires: $320
    Fuel pump: $142
    Timing belt/Water Pump kit: $375
    Ignition kit: $316 (distributor, rotor, wires, coil, plugs)
    Alternator: $130
    Oxygen sensor: $160
    Radiator: $220
    Steering rack overhaul: $500 (rebuilt rack, gaskets, boots, etc)
    Belts, filters, hoses, bushings, etc: $500
    Stipulations:
    -This budget leaves about $3000-$4000 breathing room to buy an E30 “shell” with no rust, a halfway decent interior, and functional electronics. Exterior aesthetics are unimportant as long as the chassis is sound overall. Worryingly, this $3-4000 buffer must also include unforeseen labor costs.
    -I will attempt to use the best quality parts that I can afford. Parts & kits would be sourced from Pelican Parts, BavAuto, etc.
    -I would hope to perform much of the work myself to save labor expenditures. Work I would definitely outsource: Engine and tranny rebuilds, some brake work, and new diff rebuild/installation.
    -I realize this outline is not total. It ignores electrics, shifter linkage, and exhaust (for starters). Plus, there are always little gremlins lurking about (Idle control valve, anyone?). I will obviously have to factor these issues into the “shell” purchase.
    So whatta ya think?
    Thanks for your input...
  • rturbo 930
    • Dec 2005
    • 2629
    First, when you say "total restoration" I assume you mean a bare chassis, bare metal resto. Otherwise, it's not really a total restoration.
    And no, $15,000 isn't enough. Double that, possibly triple, depending on how much you do yourself and what you can use vs what needs to be replaced.
    • Rontgen
      • May 2016
      • 137
      General rule of thumb is to add up the costs and time beforehand, as you've done.
      Then double the cost and triple the time.
      - Darrell
      2001 BMW M5
      1990 BMW 325is - Build Thread
      • BHT2109
        • Sep 2016
        • 68
        rturbo: No plans for frame-up at this time. As I wrote in the bottom, I realize it's not TOTAL; perhaps "thorough" would be a more appropriate term :)
        As for $15,000 not being enough, would you mind elaborating? Since I'm basically replacing the entire drivetrain/suspension/brakes/etc with "new" parts, what am I missing? Are you saying that I should anticipate $20-30,000 worth of unknown x-factors?
        Thanks for the feedback guys!! Keep 'em coming!
        • rturbo 930
          • Dec 2005
          • 2629
          Are you doing the work? Do you have experience? If you can do it, you may be able to do it all for maybe 25k, since it's not a total resto. Or who knows, maybe you'll come in under budget. But I doubt it. It's never, ever as simple as just buying some parts and installing them.
          Check these builds out:
          • Rontgen
            • May 2016
            • 137
            The total cost is going to be influenced greatly by the starting condition of the car. Do yourself a favor and find a clean, rust-free body with good paint and you'll save thousands. Body work and paint can easily become a financial black hole.
            If you want an is, I say buy an is. They aren't so rare that you need to spend the $$ trying to turn an e into an is. The is will also include a limited slip, so that'll save some $.
            Be patient and be ready with cash in had to scoop up a good deal on a clean E30. I recently did just that on a $2500 1990 325is. It ran, but not well and had great paint and no rust. I've pulled the motor and transmission and am doing a fairly comprehensive rebuild of the car. Granted, I'm doing all of the labor but I should be in the $5-6K total investment range when it's done. It won't be a show car, but it'll be really clean and mechanically reliable.
            Good luck!
            - Darrell
            2001 BMW M5
            • StereoInstaller1
              GAS
              • 22679
              /thread
              Closing SOON!
              Thanks for 10 years of fun!
              • jeffnhiscars
                • Jun 2011
                • 6011
                Good luck!
                This is VERY sound advice...from a noob no less :D
                Alice the Time Capsule
                • PKile
                  • Apr 2016
                  • 184
                  I am about ready to re-implant the engine and trans in my 92 325iC. The car was purchased in April with a great interior, decent laguna green repaint, and no discernible rust, but had 233,000 miles of mechanical neglect and previous owner stupidity. The major jobs I've done are as follows...
                  Fully rebuilt and balanced engine with full valve job
                  Rebuilt BMW tranny (original howled 1st -3rd gears)
                  New control arms and bushings
                  New strut inserts
                  New tie rod ends and rack boots
                  New steering column u-joint
                  Replaced front crossmember (original swaybar broken off)
                  New full exhaust with cat
                  New oil cooler and lines
                  New flywheel and clutch
                  New clutch master and slave and flex line
                  New gas tank with all new fuel and vent lines
                  New front brake pads
                  Front caliper rebuild kits
                  Stainless braided brake lines all around
                  Reconditioned driveshaft
                  New 15" Euroweaves and Dunlop Direzzas
                  Hella BiFocals and Cibie H1 high beams
                  New A/C condenser, dryer, and flex lines
                  CD43 head unit
                  Along with all that came a truckload of new hoses, hardware, clips, fasteners, and trim bits., not to mention new fluids, filters, sealants, lubricants, manuals and special tools to accomplish all the tasks, and a 1,700 buck machine shop bill.
                  If I subtract out $6,000 for the car purchase and DMV pound of flesh, that leaves a grand total of $17,000, not counting my labor (this is my retirement hobby, you understand). Judge for yourself if I am insane...
                  • 88BlackS-ETA
                    • Mar 2013
                    • 322
                    Insane, no. Enough money, only if you do all the labor yourself (except engine and tranny rebuild). Any M20 can go for ever if you do the maintenance on it correctly. I pretty much did a 'frame up' resto and it took a long time and wasnt fun. They only thing I didnt do was remove the undercoating or the engine wiring harness. Total coast: not adding it up because I dont want to know.
                    Stripped straight down to metal does take a long time (I know from experience). So like you and others said, get a straight shell with good paint.
                    Feedback Thread
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      New strut inserts
                      CD43 head unit
                      You forgot to mention your shiny new seat shocks...but if you factor in the savings from all the lattes, tequila and cocaine you didn't do because you were busy fixing your car, you came out ahead....and yes, of course you are insane...just like the rest of us :)
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        You are only insane if you total up the amount you spent on it.
                        I did a spread sheet on my M3 refurb, and got about half way through the stack of receipts and accidently hit the total button.
                        I looked at it for about 30 seconds and then deleted the file. I don't want to know.
                        Originally posted by codyep3
                        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                        2001 silver/Blk 325 cabby. SOLD
                        2002 325xit Sil/blk. SOLD
                        2010 F650gs twin
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          Im 20k+ in my "total" restoration and i still don't have a interior
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • PKile
                            • Apr 2016
                            • 184
                            I don't mind knowing the total, but God help me if my wife stumbles on the information!
                            • PKile
                              • Apr 2016
                              • 184
                              You got that right, Jeff! Speaking of vices (other than my 5" Wilton) my wife knows I'm not boozing or catting around because she always can find me in one of 3 places...my garage, the local Pick and Pull, or the parts counter at BMW!
