My car needs the fuel pump to be replaced .im also planning on doing an m50 swap over the winter. Is the fuel pump something i should do before the swap or does it not matter
Fuel pump
Do the pump(s) now. A pump failure could leave the car stranded somewhere.
You didn't say what year the car is. If an ETA or early 325is there will be two pumps. A lift pump in the tank and an external high pressure pump. Later cars have only an in-tank high pressure pump. Change the filter when you replace the pump.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
