Hydraulic handbrake is not working
  • Hyfly
    • Oct 2016
    • 9
    Hey Guys,
    I have installed an hydraulic handbrake last week, and it is not locking...
    Started with the 0.75 cilinder, didnt work.
    Ordered the 0.625 cilinder, worked a bit better, but is not locking.
    Is there anyone who experienced the same thing after installing?
    The brakes work as they should, I took them apart after the 0.75 cilinder
    was not working and checked them.
    Regards, Stefan
  • Reub_e30
    • Apr 2016
    • 145
    So I take it that u are running a dual caliper setup. Did you bleed the line properly? You did add brake fluid right? Checking just in case lol
    Daily: 06 Chevy Colorado (wannabe racetruck)
    Drift/Track Car: 91 Bmw 318i 4dr
    • TobyB
      • 5263
      It's a matter of leverage or travel. Or maybe coefficient of friction?
      But the details are hazy- we'd need more pix to figure it out using this poor tool called
      'the internets'...
      A long time ago, I wanted a .500 x 5" master cylinder for my clutch. Sadly, no luck...
      t
      • Hyfly
        • Oct 2016
        • 9
        I'll try to take a picture later today.
        But to be ahead of the game:
        - I bleeded the lines with a garage vacuum bleeder so should be fine.
        - It is a single line into T-peice for both OEM calipers, not a dual caliper setup
        It is an in-line hydraulic handbrake.
        • TobyB
          • 5263
          So you've disabled the stock rear brake?
          It gets interesting to try to keep stock rear brakes with an additional hydraulic handbrake...
          t
          • Reub_e30
            • Apr 2016
            • 145
            So you should have installed like this correct?
            • czkb
              • Feb 2015
              • 21
              Put this
              before e-brake not after, or it wont lock, had same problem with my 0.70.
              • Hyfly
                • Oct 2016
                • 9
                @ Reub E30, Yes excactly like that.
                @ czbk: What is that? A brake pressure limiter? And where can I find this on my E30 316?
                • jpod999
                  • Dec 2015
                  • 1401
                  Look underneath the fusebox in a LHD E30.
                  OBDI M62B44/6 swap
                  Transaction feedback
                  - jpod999
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    You probably want to go with a BIGGER master cylinder, not smaller. I bet you aren't moving enough fluid to fully actuate the calipers. Larger bore will flow more fluid for the same amount of throw. It will be harder to pull though.
                    • Hyfly
                      • Oct 2016
                      • 9
                      I checked the travel of the calipers, they are more then sufficient. I had a 0.75 cilinder before this one and was even worse. (On brakeforce that is)
                      And the pressure restrictor is before the handbrake, because I tied in under the drivers seat.
                      I will try bleeding it manually next week once more...
                      • Madhatter
                        • Oct 2004
                        • 966
                        smaller cylinder = more force. Not the other way around.
                        Just a little project im working on
                        - http://www.lse30.com -
                        • Hyfly
                          • Oct 2016
                          • 9
                          Correct, but what Andrew says is also correct.
                          Smaller cilinder could mean less liquid to move the pistons.
                          • pazi88
                            • Sep 2015
                            • 584
                            Are you sure the rear brakes are really working? Maybe stuck pistons because corrosion? With that setup you should be able to lock the rear tires easily. With both cylinder sizes.
                            • Hyfly
                              • Oct 2016
                              • 9
                              I will check everything again this weekend.
                              It is just so weird that it is working so badly, and others say they can pull with one finger to lock them up....
