205/60-15 issues
  • rwh11385
    lance_entities
    • 18403
    205/60-15 issues
    I know they are oversized, but are there any concerns besides inaccurate speedo or changed final drive ratio? I know some people choose to run 205/50 or 215/50 and the correct size is 205/55, but are there any real problems will running this tire size? I just wanna be sure.
    Thanks in advace. (No flaming neccessary)
  • Sean
    • 5793
    Nevermind - guess my post was useless.
    You already know about the oversized part, so, please, carry on...
    - Sean Hayes
    • UNHCLL
      • 8790
      Originally posted by Sean
      Other than a really big sidewall that may look really bad, I don't see what would be wrong... ;)
      Dont post random dribble that has no relevance please... you got 10x worse once you took delivery of Kris' car.
      205/60 is fine, no issues with final drive or anything like that. speedo inacuracy is negligeable anyways... add to that the fact BMW speedo's read high and its pointless.
      Below the radar...
      • rwh11385
        lance_entities
        • 18403
        Cool. 8)
        I'm movin to 15" and will need tires to just get around for a while. And I obtained some in 205/60 that will "do" until I can get 225/50...... I believe 205/60 Yoko Avid H4 will "do" ;)
        Chris, thanks. :up:
        • e30virgin
          • 62
          i also have 205 60 15's and the only thing i don't like is the sidewall roll in hard corners. Thinking abou doing a 205/ 50. anyone else do this?
          • rwh11385
            lance_entities
            • 18403
            Um. They rub.
            The tires do rub in the front, even at small angles of the steering. But they rub the tread, so no biggie. Right up against the fender liner in front of the wheel.
            I blame the E30 M3 control arms. It moved the wheel forward and increase castor. Doesn't make rubbing noises when at speed though.
            It's cool. I think I can live with them at least. I have to think about the next step. ES100's..... I dunno.
              • 34839
              Originally posted by rwh11385
              Um. They rub.
              don't the M3 bushings give it more castor?
              you have GC right? why not just raise it up until you wear those out and can buy another set.
              • rwh11385
                lance_entities
                • 18403
                E30 M3 Al Control Arms (And bushings)
                I'm not sure if brining it up would help. Maybe a little, but the fender liner is pretty vertical in the section it is rubbing.
                • Bill 84 318i
                  • 1600
                  The aluminum arms have the same geometry as the steel ones. It's the bushings that push the wheel slightly forward.
                  And don't blame the arms/bushings, blame your bigass tires.
                  • rwh11385
                    lance_entities
                    • 18403
                    Ah, I see. Yeah the offset bushings.
                    Bigass tires Those were probably a mistake. Maybe I can hand them off to a friend with a 240SX and use that to help get some correct tires.......
                      • 34839
                      if you bring up the car a little bit, it will affect your castor and bring the wheel back a little bit. adjusting GC is easy, it's probably worth a shot (looks aren't everything, right? :P)
                      I suppose you'd want to wait until you get your taller rear springs though.
                      • rwh11385
                        lance_entities
                        • 18403
                        I'm hoping selling my head/injectors the 11th in Chicago.....so maybe I could hit up Tirerack on my way home. :) Hopefully.....do you know how much they charge for mount/balance?
                        205/55-15 ES100s. :twisted:
