Aux Fan Trouble
  • Dirty_30_IS
    • Jan 2016
    • 179
    Aux Fan Trouble
    Is the Auxillary fan (driven by the A/C and also when car is very hot) rebuildable? Mine isn't working, its not the resistor, when I jump it and run power to the fan it wobbles and grinds as if it has a bad bearing.
    1.Should I just bite the bullet and buy another OEM one?
    2.Can I rebuild my current one?
    3.Has anyone run another aftermarket one with any response to how it preforms?
    Like I said, my car isn't having overheating issues, the low speed fan just tears itself apart on the low speed when I flip the A/C on. The only time I get cold air is when I'm flying on the highway.
    sigpic1990 325IS,
    2.7L bottom end, Shrick 272 Cam, and a heck of a lot of bald tires.
  • vpilarrt
    • Jun 2006
    • 2096
    I have a good OEM one if you're looking. PM me.
    • jeffnhiscars
      • Jun 2011
      • 6010
      Easiest fix is a good used one, which is obviously easy to find. Being in the AC belt if you are inclined to an upgrade get a 14" SPAL pusher and skip the resistor so it runs on high only
      Alice the Time Capsule
