No heat + Plus Temp Gage in the blue.
  • Llama69
    • Dec 2016
    • 4
    Okay so I changed my first brown temp sensor already, Tightened the nut on the back of the cluster and replaced the SI battery and still nothing.
    My temperature gauge maybe moved about a couple mm when it starts and stays there barely touching the blue.
    Is it possibly the T-stat? I already have a new Timing kit I was planning a installing this wednesday.
    Thanks!
    1990 325is
  • superj
    • Feb 2006
    • 397
    It could be but also check to make sure the valve inline with the heater core isnt stuck closed.
    We have the opposite trouble, i have no heat and my gage reads in the red. My heater core valve is stuck closed though
    • noid
      • 1537
      Sounds like your thermostat is stuck in the open position.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • Das Delfin
        • Sep 2014
        • 2293
        t stat stuck open
        • gearheadE30
          • Jun 2007
          • 3734
          yeah, I've had 2 tstats break in the last ~100k miles with the same results.
          Project M42 Turbo
          • Llama69
            • Dec 2016
            • 4
            Thanks for the replies guys! I'll be doing my timing, water pump, and tstat on Monday. Will post if that solves my problem.
            • Gregs///M
              • Mar 2012
              • 2459
              Thanks!
              1990 325is
              FYI, changing the batteries on the SI board alone rarely repairs the SI board. There are about 25 capacitors, transistors and voltage regulators that must also be changed. When the 30 year old batteries fully drain, they cause the transistors to turn on and off rapidly leading to failure. Ever tap on your dash or cluster to get your cluster working? That's the transistors getting stuck.
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
              • Llama69
                • Dec 2016
                • 4
                Yea i tried tapping it many...many... times haha..nothing. Tstat will be changed tomorrow morning actually do we will know then.
