Cluster removal issue
  • bimmerR75
    • Jan 2016
    • 251
    So after taking everything off that holds the cluster in place. Whomever owned the car before, both of the "A" clips are snapped off, which after about 25 minutes of trying to wiggle the cluster out, I gave up as I felt i'd rather not break it.
    Any suggestions on how to get it out without those "A" clips? Specific tool that won't damage the cluster while pulling it out? A hook perhaps? haha
    If I had to live my life over, I'd live over a Saloon" - WC Fields
    Garage
    1991 325i
    1972 R75/5 Cafe
  • jeffnhiscars
    • Jun 2011
    • 6010
    Assuming it's a non airbag car remove the underdash cover. You should then be able to reach up and tilt thentop of the cluster forward.
    Alice the Time Capsule
    • bimmerR75
      • Jan 2016
      • 251
      Its an airbag car unfortunately
      Garage
      1991 325i
      1972 R75/5 Cafe
      • MR E30 325is
        • Dec 2008
        • 3300
        You can still unbolt the silver metal looking thing after you take the knee bolster off. Should be able to reach up and push on the back of the cluster to get it out.
        Also, a dental pick with a 90 degree hook on the end might work.
        My previous build (currently E30-less)
        http://www.r3vlimited.com/board/showthread.php?t=170390
        A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
        • six2midnight
          • 326
          agreed, this is easily done in an airbag car too. take off knee bolster panel (if you even have one haha) and the metal support that goes across (10mm bolts)
          make sure you removed the 2 knurled knobs under there too to get the plastic piece off. you should be able to see the cluster pretty easily. you can push it out.
          I hope you have the steering wheel off as well. a lot easier.
          if all that doesn't work, y not try a suction cup? like a valve lapping tool?
          http://www.homedepot.com/p/GearWrenc...g&gclsrc=aw.ds
          Race German
          Automotive clothing from your favorite brands included: CAtuned,
          UUC, Garagistic, Revshift, Moar Designs, Condor Speed Shop,
          Neue Motorsports, Bimmerheads, Motorsports Hardware and more.
          Also offer track decals for any track in the world.
          :thankyou:
          • superj
            • Feb 2006
            • 397
            I guess that since this guy never came back, he got it out.
              • 34839
              I've pulled the cluster out of my airbag car a couple dozen times, I never remove the steering wheel - I don't find it any easier anyway.
              • six2midnight
                • 326
                just gives a little more room, not working through the steering wheel. and steering wheel is 1 nut, takes me literally 26 seconds to get it off
                Race German
                :thankyou:
                • IceWhite
                  • Jan 2015
                  • 945
                  The main problem for cluster removal virgins is the question of how to wiggle the cluster out with the "A" Clips and steering wheel in their respective places. In OP's case he doesn't have those "A" clips.
                  1990 325i
                  2004 330i Individual 6-speed
