Fuel gauge always reads empty, please help!
  • smurphy_e30
    • Oct 2013
    • 162
    Hey guys before you say it, I did search and everyone's gauge seems to always read full. But mine reads empty, all the time!
    My fuel gauge worked fantastically, then one day my car was about empty so I went to fill up at the pump. When I started my car up, the gauge stayed at empty, I figured it would slowly creep to full but instead as I was driving down the road the gauge started to jump around. I thought it was the ground on the back of the cluster so I tightened the nut and now it stays at empty.
    I have replaced the passenger side level sender with a slightly used one, but no change. I'm wondering if the driver side sender is out? Or it could be something in the cluster?
    Any help would be greatly appreciated!!
  • dnguyen1963
    • Nov 2011
    • 2651
    Your fuel floater might be stuck. Remove the fuel sender. There should be a few small holes in the aluminum housing that holds the floater. Spray carb cleaner in there then shake it up and down. The floater should move without any restriction. If not then repeat the cleaning cycle a few more times.
    • smurphy_e30
      • Oct 2013
      • 162
      When I replaced the passenger side sender about a month ago it moved freely, could the driver side floater be stuck?
      • Gregs///M
        • Mar 2012
        • 2459
        Try replacing fuse 10, 12 and 21 first. If one popped, no movement on fuel gauge.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5604
          maybe you didn't plug it in well when you replaced it and it popped out.
