Stomp Test wont work, weird intake boot?
  • TomIV
    • Feb 2017
    • 13
    just bought this car, trying to figure out if this is messing with the TPS or something thats effecting the stomp test from being performed. The intake boot looks crammed in there.1991 325i coupe
  • roguetoaster
    Biggus Tippus
    • 7830
    Can't enlighten you about your intake boot, although that's probably not a factor. But if your stomp test is not working (and your car actually has that function), you can roll the window down, key it up and try actuating the throttle by hand in the engine bay.
    If that doesn't work you might have a bad TPS.
    • ELVA164
      • 4861
      It looks like the power steering reservoir has been bent away from the strut tower and into the boot. Bend that away again and that should hopefully fix the crush.
      • mr.vang
        • 4371
        Loose the boot clamps and readjusted it. When I bought my e30, the previous tight one clamp before aligning it with the ICV & hose causing the boot to twist.
        • 7pilot
          • 475
          Looks like an older intake on the engine.
          My 10/88 production car has the same style intake plumbing as the one in your picture.
          My 2/90 production car has a cleaner idle valve routing.
          Make sure that the engine is getting air...air filter totally clogged??
          Either way, I would suspect that the boot is no longer sturdy enough for use.
          Cannot have that collapsing, under throttle.
          m
          • TobyB
            • 5239
            I also question how that 'WOT vacuum assister' thingus is plumbed- the hose going to it looks pretty sketchy. And unfamiliar. I ditched mine, so I don't remember how it's supposed to go...
            t
            • ELVA164
              • 4861
              Quick comparison:
              Yours
              Another example
              It appears to me that:
              1. Your intake is too far back in the engine bay. This is tweaking the boot, causing its collapse. This also appears to be the cause of the weird ICV angle and the location of the vacuum hoses coming from the brake booster.
              2. Your ICV might not be plugged in? The lighting isn't very good, but I don't see the plug, nor the wire, nor the rubber clasp that usually holds the ICV in place.
              3. It appears someone capped off the pre-heater for the throttle body. This could cause some cold-running issues.
              That should be a good start, please report back.
              • Gregs///M
                • Mar 2012
                • 2459
                Your TPS looks like it still has clearance and is held on with two bolts. If your stomp test is not initiating, there is a good change the TPS is not adjusted properly. See bentley manual for proper adjustment of the TPS. WHen adjusted correctly you will find your stomp test working again and your car will probably idle better too.
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                • Seawolf
                  • Feb 2015
                  • 270
                  That setup isn't correct, you need to get a new intake boot.
                  The intake boot angled outlet that connects to the angled inlet of vacuum line should not have an additional hose on it, the intake boot connects directly to that angled pipe. The additional 2" (ish) of rubber hose is pushing the intake boot backwards and distorting it.
                  Look at the marked up pic provided by ELVA164 and you'll see what I mean.
                  The ICV should have a mounting bracket underneath it and a rubber sleeve that mounts on the bracket, I dont see either of these in you pics.
                  • ELVA164
                    • 4861
                    Good eye! Didn't notice that.
