Need some opinions/help with my brakes
  • unitt01
    • Oct 2014
    • 513
    So my brake light has been flickering on and off lately and pretty sure my brake pads are done. Currently broke at the moment and can't afford a complete brake upgrade/tune up (new hoses, new pads, new discs, new sensors). Was wondering what do you guys think if I just replace the pads along with flushing my old brake fluid and putting new brake fluid ?
    FS: Plug n Play Second Trunk Light !
    My Parts for Sale Thread~
    x 1984 325e 2.7i ~ CastroMotorsport Built x Daily Driven
  • TobyB
    • 5280
    That's a lot safer than doing nothing, as long as the rotors aren't totally shot.
    I often do this too, if I'm pretty sure everything else is ok.
    t
    • roguetoaster
      Biggus Tippus
      • 7830
      If you're 100% broke you should ask in your regional section if anyone has a decent set of used pads. Used pads will be just as good/bad as new pads on old rotors.
      If your sensors are causing a light you can join the wires outboard of the plug to make the light go off.
      • unitt01
        • Oct 2014
        • 513
        i'm not 100 percent broke but I was thinking of picking up some cheap brake pads from autozone. I already have a brand new can of ate dot 4 brake fluid so I would just be picking up some pads. I'm not sure how to inspect my rotors for any signs of wear tho.
        • badwella
          • 357
          Here's a checklist to check your rotors:
          You can get rotors from Rockauto for around $15 each (not Brembos, of course) and pad sets for less than $10 for front or rear. That's seriously cheap.
          Remember, it's your life on the line. I recommend cutting money from other aspects and investing in something that will protect you.
          You can get used pads from pick n pulls for dirt cheap too. My local pick n pull only charges $1 per pad.
          P.O.S 1989 325is - aka Project Sh*tbox
          Project Shitbox - Restomod and other stuff - soon to be 328is
          • unitt01
            • Oct 2014
            • 513
            Sweet. That inspection list is so helpful. Thanks for that, I will check them tomorrow morning. And yeah I've seen rotors for cheap but I rather just save up to get some brembos or zimmermans by next month or so along with everything else for the brakes.
            • jeffnhiscars
              • Jun 2011
              • 6011
              my machine shop turns my rotors for $13@ and he actually recommends turning new ones since they are rarely true. Bww says don't turn them but as long as they are above a certain thickness it's fine
              Alice the Time Capsule
              • roguetoaster
                Biggus Tippus
                • 7830
                IMO, the cheap rotors aren't going to be an issue unless you drive aggressively or track your car. However, I wouldn't buy a no-name/off-brand brake pad, and would spend the extra on that aspect of the system while running off the shelf Valvoline DOT4.
                • unitt01
                  • Oct 2014
                  • 513
                  Yeah you have a point but I do drive pretty spiritually at times.. And of course buying a off brand brake pad is sketchy as is to why I mentioned autozone since their duralast brake pads aren't that bad. (my dad and I have been using those pads for the last couple of years on our pickup and suv with no issues so far)but when I do go all out on upgrading my brakes I want to pick up some Hawk HPS Street pads which have a ton of good reviews. As for brake fluid I picked up some ATE typ 200 Dot 4 a while back as to complete my purchase with free shipping lol
                  • TobyB
                    • 5280
                    I go with Budda...
                    hee
                    t
                    • TimeMachinE30
                      • Jun 2014
                      • 3749
                      Remember, it's EVERYONE'S life on the line. I recommend cutting money from other aspects and investing in something that will protect you.
                      Don't be selfish.
                      ACS S3 Build / Dinan 5 E34
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Made me think that one should blatantly steal them, and run out shouting "you'll never stop me!"
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          See if the rotors are within spec and pad smack that shit!!, new fluid is obviously good too. 2 year maintenance item on the fluid, some people at the dealer have legitimately black fluid and it's still okay for "normal" driving so it's not the biggest concern but obviously not optimal- particularly if you beat on the brakes
                          BMW tech
                          Umass Amherst
                          05 wrx sti
                          • unitt01
                            • Oct 2014
                            • 513
                            Originally posted by TobyB
                            I go with Budda...
                            hee
                            t
                            'Spirit-ly' lol i blame autocorrect.
                            So the rotors seem to be in acceptable shape so I will just be changing the pads and fluid although my brake lines do have wear..
                            Now time to save up and work some overtime haha
                            • bmwstudent
                              • Sep 2011
                              • 1364
                              Its funny, I'm on the other side of the country but I must have about ten sets of rotors and calipers and pads. All used takeoffs from cars I've dismantled. A lot of the stuff I have I'm willing to give away to anyone here on R3v but it is pick up only
