Weak Wipers
  • ziazhp
    • Nov 2015
    • 191
    Weak Wipers
    My wipers work, but are extremely slow and the different speeds are delayed. Is this a wiper motor problem (slowing dying motor) or relay module? Is there any easy diagnosis? For point of comparison, I have access to another E30 that has perfectly working wipers. Any insight is appreciated.
    Thanks
    '89 325ix
    '88 M6 Royal Blue
    '13 128i "M-Sport"
    '04 ZHP Mystic Blue-SOLD
    '02 E46 330xi-SOLD
    '89 325i Laachssilber metallic-SOLD
    '89 325i Bronzit-SOLD
  • TobyB
    • 5296
    I would start by lubing the cowl pivots. It's hard to get lube in there...
    t
    • grahamsy2k
      • 400
      I have the same issue. For me I believe it is the motor because the wipers move a lot faster when its raining. So I'm assuming there is less resistance on the motor when it rains.
      All just means to an end.
      • CanadianDirty30
        • Sep 2015
        • 173
        had the same problem, definitely the motor. Mine could barely make all the way across the windshield and back, then sapped out the motor and it was back to regular power.
        91' 318is Brilliantrot
        Yes, it still has an m42
        • jeffnhiscars
          • Jun 2011
          • 6011
          An often overlooked part of the wiper system (besides the wiper dampers which are always old and cracked and allow your wipers to wobble and die) is the crank arm that attaches to the bottom of the motor. It's a "breakaway spline" just like where the blade arms attach. Worth checking
          Alice the Time Capsule
