Coolant Leaking From Side of Car?
  • Metallated
    • Dec 2016
    • 1074
    I have a very similar issue and the plug is missing for me, do you think it is just water getting thrown up into the foam from driving in wet weather or is it something more serious?
    • rustneversleeps
      • Aug 2016
      • 132
      So is that an indication that it's leaking from the heater core..
      Green doesn't look right...
      • Boris3
        • Apr 2007
        • 444
        If not a heater core leak there could be a hole in the floorpan letting water in. Mine was rusted through near the gas pedal and soaking the carpet when driving in the rain. Water would then leak out around the floor plug.
        Either way pull the carpet to see if there is a heater core leak or a hole in the floor pan.
        1990 325: track/racecar
        2003 330xi; project car
        2004 330i zhp: civilized car
        • TobyB
          • 5297
          a hole in the floorpan letting green water in.
          does it glow in the dark, too?
          t
          • jhaurimn
            • Nov 2012
            • 2224
            Your heater core is most likely leaking. Check the carpet near the pedals to confirm.
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • AndrewBird
              The Mad Scientist
              • 11898
              If not heater core, then heater valve.
              • Yeltsew7
                • Feb 2017
                • 71
                Yep, it's the heater core. I checked and the whole drivers side is soaked with coolant.
                I'm going to just block it off for now since it's summer in Florida and I just don't want to lose any more coolant. I won't need heat for 6 months or so.
                1988 325is - Totaled, Hit and Run
                1994 530iT - Rusty, Not Running, Gone
                1989 325i - Clean Body, Barely Runs
                • D.Martijn
                  • Sep 2016
                  • 1024
                  I would suggest taking the carpet out and getting it dry. Also a good time to check for possible rust.
                  1990 325iX Touring - November 2018 R3V Car Of The Month
                  1980 Volkswagen Golf mk1 1.1
                  1974 BMW 2002 Touring
                  Instagram
