MS3x Wiring HELP!
  • NEOe30
    • Jun 2016
    • 415
    MS3x Wiring HELP!
    So, now that photobucket has decided to take a dump on all forums, I am without much support for getting my MS3x setup with my m50. I have found the following diagrams which i believe to be quite helpful, but I can't find much information on the relay circuits due to all the photos being taken down everywhere. I would really appreciate any help that anyone has to offer, the timing couldn't be more inconvenient. Hopefully this belongs here and not in the car audio/electronics subforum.
    This is what I have found after a few hours of searching. I am also unsure of what "FN" stands for in the column titles. Function?
    General Diagram: http://www.megasquirt.325ix.com/MS_t...c%203.3.1.html
    Grounds Diagram:
  • NEOe30
    • Jun 2016
    • 415
    to add to this, I have an m50nv. I believe those diagrams are for a Vanos engine, so i am stuck.
      • 34839
      Yes, I created that diagram for a VANOS harness (what I used on my M20). However, it's really similar. Download an ETM for an M50NV car, and just compare the pins where they are different. the megasquirt side will be the same, I think mostly the injection harness is what moved pins at the DME.
      yes, FN means function.
      • NEOe30
        • Jun 2016
        • 415
        awesome, thank you, ive been wiring in anything that's the same to get a head start.
        by etm, are you referring to the WeDoPhones chart with the ecu pinout? Ive been trying to create my own spreadsheet to eventually share. The biggest issue is that I have ms3x and a m50nv so only a few of the wires match up with your chart and actually makes sense to me.
        • shootnjunky
          • Aug 2014
          • 506
          there is a new shop in richfield that might be able to help you as well. they are currently helping me with my s52 swap. its called flitzen factory
          • NEOe30
            • Jun 2016
            • 415
            thanks! I have a local shop that's willing to offer help, I actually ordered it from them and had my downpipe made. Cool guy actually, however I'd take a lot more pride in it if I wired everything up myself by reading the diagrams etc.
            • NEOe30
              • Jun 2016
              • 415
              I have created a wiring diagram/spreadsheet if anyone is willing to look it over...
              • NEOe30
                • Jun 2016
                • 415
                just cant get the car to connect to megasuirt now, any help is appreciated
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Have you tried connecting outside the car and using a power source?
                  john@m20guru.com
                  Links:
                  • NEOe30
                    • Jun 2016
                    • 415
                    hey there, I think I know my issue... feel so stupid for overlooking it but im a first time MS'er here. I ONLY have the top harness plugged in (expansion board?)... I have a clip for the bottom harness (main board I believe?) but no wires, so i think thats a mistake by my tuner for not ordering the harness... nonetheless, what wire #s do i need to connect on the bottom plug to power it up?
                    also, how would i go about connecting outside the car? thanks for your patience.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Can you post pics?
                      john@m20guru.com
                      Links:
                      • NEOe30
                        • Jun 2016
                        • 415
                        Can you post pics?
                        Here is the wiring harness I'm using, top port only as I said... Not sure if i need the other. Along with my vaccum/boost source.
                        Here is the other side of the MS3x, just my USB A/B cable for connecting to laptop.
                        And finally the extra plugs that came with the kit... pretty sure the small one is for add-ons like wide band, etc, but not sure. No clue about the longer one.
                        • NEOe30
                          • Jun 2016
                          • 415
                          Anyone? Do I need the bottom harness?
