Tools for the job - What is necessary for an E30?
  • Jand3rson
    • 37587
    Well, the new E30 is coming next Sunday. I'm going to start working on it immediatlely, but my last set of tools is bye-bye. Apparently, it was in the trunk of the car when it was hauled away (D'OH!). Not that it was much good, it was one of those $50 sets they have at Wal-Mart or something, my Grandma got it for me for X-mas.
    I'm going to be buying all new tools, and I want to know what eveyone thinks is the essentials of an E30 toolbox. So let's hear it.
  • kencopperwheat
    King of Kegstands
    • 14396
    A metric ratchet set (w/deep and short sockets).
    Some people have told me I have an amazing ability for stating the obvious.
    Originally posted by Gruelius
    • Brian 89 325i
      • 1450
      No brainer
      Metric wrenches
      Metric sockets
      hammer :twisted:
      BENTLY
      few torx
      screwdrivers
      Extensions and Uni joints
      Just general tool stuff. Not TOO many E30 specific parts
      Specific
      Thin walled 32(?) MM socket for the tranni output flange
      Angled gapper set for adj valves
      Feel free to add on
      Brian
      • Erick
        Official R3V Drifter
        • 11169
        22mm socket for the steering wheel :P
        A cooled beer
        Metric wrenches with one full ring on one side ( a lot better grip than a regular wrench like the ones in the trunk )
        etc etc.....
        I need a toolbox......
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
          • 34844
          You'll need sockets from 8-22mm, a 30mm socket for the wheel hub nuts (32mm on the ix), wrenches from 8-22mm, a 32mm thin wrench for the clutch fan, inverted torx sockets, metric allen key sets (and allen socket sets), a torque wrench (150 ft-lbs or more), a breaker bar (don't use a torque wrench for this!), floor jack, jackstands, feeler gauges (for adjusting valves), screwdrivers, a BFH (my 1lb deadblow is too small), a nice collection of pullers, spring compressor, pipe wrench, uhh.. I think that's most of the important stuff I have, there's probably more.
          This will allow you to do pretty much anything to your car, including suspension, drivetrain and engine work. A jumper wire with an inline fuse can be used to reset your SI lights, a multimeter is very useful for electrical problems and to test sensors, and a brake bleeder tool (to pressurize the system) is extremely helpful when bleeding your brakes.
          • Jand3rson
            • 37587
            Thanks guys, that should just about do it.
            BTW, I hope this thread didn't make everyone think I was a retard, I just forgot all the specific tools I had for working on my car. :D
            • Ryan Stewart
              I Love Miatas
              • 8978
              make sure when you get sockets to only get the 6 sided ones. A lot of those cheapy ones are the 12 sided and those are great for stripping nuts.
              17mm deep well socket is great for the lugs if you have a bitdriver.
              Im now E30less.
              • kencopperwheat
                King of Kegstands
                • 14396
                17mm allen wrench (or that ratchet bit that BavAuto sells for $25) for the transmission drain and fill plugs.
                • LikeCDoos
                  • Jan 2004
                  • 2522
                  i'd also get a test light...those things are great. I've used them many times to figure something out or rewire something in my car or a friends.
                  • reelizmpro
                    • 9552
                    Assortment of metric sockets, box and open end wrenches with extensions and swivel. 10mm/13mm/17mm are commonly used all over the car. Also get a set of allen wrenches, phillips and flatheads. Don't get a set of vice grips. 1/4" rachets also help get into those tight spaces.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • 325 eta
                      • 472
                      metric allen wrench set for the rotors. floor jack, digital camera so you know how to put the shit back together! (i assume your doing a lot of mods). if you can get air tool bc they
                      eveything do much easier.
                      • darien28
                        • Jan 2004
                        • 240
                        personally, I'd goto sears and pickup a set of metric tools... lifetime replacement so u can abuse the shit outta the tools and when it breaks... get another one free.
                        in addition to all the normals stuff, you might want to consider investing in an aluminum low prifile jack from harbor freight tools ($99) if you're lowering your car and need to lift it up a lot. those 3ton giant floor jacks are a PITA and they're heavy as #@$%.
                        other than that...
                        that's bout it.
                        oh, and a $10-20 voltage tester for electronics troubleshooting is good too.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          I would also say a good 12 volt battery charger. Don't need anything special, but just something that will charge a battery over-night if needed. Get a nice tool box while getting all the tools too. Nothing sucks more then working out of a card board box. :roll:
                          Andrew
                          • Matto
                            • Jan 2004
                            • 800
                            Originally posted by rwdrift
                            A cooled beer
                            Beer + car mechanical work = BAAAD :evil:
                            • Jand3rson
                              • 37587
                              Andrew
                              Yeah, I seem to remeber having to do that at one point...
