Drivetrain fitment between models
  • krazy
    • Jan 2017
    • 46
    Hey all,
    I'm buying a roller which is a 87 325i. My current chassis is a 86 325(e).
    From the roller, I'd like to remove the:
    • driveshaft
    • manual transmission (and related parts i.e. pedal box)
    • 3.73 LSD (yeah, it was an upgrade on the 'i')
    ...and put them into my current chassis. The current chassis has an 'i' exhaust manifold mated to a full 'i' exhaust system (cat and muffler). Everything else is otherwise stock eta parts.
    Does anyone know if there will be any fitment issues for these parts between these two models?
    (Yes, my current chassis had an ECU swap and is running Motronic 1.1 like the roller is.)
    Thank you!
    current:
    89 325i
    previous:
    87 325i
    86 325 stroker frankenstein
  • TobyB
    • 5296
    Depending on month of the 86, you may find many of the connectors are different.
    Look at the diff- the speed sensor was one that changed shape.
    hth
    t
    • krazy
      • Jan 2017
      • 46
      What's the go-to way to address that?
      current:
      89 325i
      previous:
      87 325i
      • jeffnhiscars
        • Jun 2011
        • 6011
        A 5 spd from an i will not have the mounting holes for your eta cps.
        Alice the Time Capsule
        • TobyB
          • 5296
          My come-from way of dealing with the sensors
          was just to swap the connectors that were a problem.
          The sensors themselves seem to be the same, it's just the wiring.
          But Jeff brings up a good point- an eta needs an eta trans...
          t
          • krazy
            • Jan 2017
            • 46
            Good looking out. Luckily, my crank sensor was replaced with one from an 87 'i' (same year, modelwafflesas the roller) when my mechanic converted it to Motronic 1.1. (I got this eta 'stroked' with all the parts from a full 87 'i'.)
            Thanks for the info, everyone!
            current:
            89 325i
            previous:
            87 325i
