Central locking working perfectly except for driver's lock.
  • RenaissanceMan
    • Aug 2004
    • 237
    My central locking system is working properly with the exception of my driver's door lock. It will only lock itself and not the other doors. However, it will successfully unlock all doors. Behavior is normal when locking or unlocking using the passenger door lock or trunk lock. (I have a coupe.) I have looked over some threads here and the common issues. However I didn't find a thread with my exact problem. Does my issue sound like a microswitch problem in the driver's door lock since it is the only one misbehaving? Thanks for any insight-
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
  • spare
    • Jan 2016
    • 42
    Inside the actuator is switch that sends the lock signal to the other doors.
    Could be the actuator or the wiring.
    Sent from my Pixel XL using Tapatalk
    • reelizmpro
      • 9464
      Easiest thing to do is check the door jam connector for corrosion and clean it out to see if that is the problem. Then look at the door actuator itself, etc.
      88 M3 - LACHSSILBER/SCHWARZE
      • jeffnhiscars
        • Jun 2011
        • 6010
        Does the drivers door lock and unlock smoothly with the key ? I dont recall off hand if a worn cylinder can impact central locking but thought Id mention it
        Alice the Time Capsule
        • RenaissanceMan
          • Aug 2004
          • 237
          Pardon my ignorance... What is the 'door jam connector?' Are you referring to specific wiring? Thanks-
          '90 325is/S52
          '76 2002
          '74 2002tii
          '06 325i sedan
          '05 X5 3.0i
          • RenaissanceMan
            • Aug 2004
            • 237
            Yeah, it seems to. There is a slight amount of friction but it doesn't seem out of the ordinary.
            '90 325is/S52
            '76 2002
            '74 2002tii
            '06 325i sedan
            '05 X5 3.0i
            • Das Delfin
              • Sep 2014
              • 2293
              hey, what was your solution here? I have a similar problem but with the trunk lock
              • RenaissanceMan
                • Aug 2004
                • 237
                My problem was verified to be the actuator, but I still haven't replaced it. :)
                '90 325is/S52
                '76 2002
                '74 2002tii
                '06 325i sedan
                '05 X5 3.0i
