Can't Remove Throttle Cable from Firewall!!
  • bmwdude
    • 268
    I'm replacing my throttle cable. Disconnecting it in the engine(throttle body) is a 30 second job. Removing the hook end of the old cable in the footwell also easy. I seem to be having trouble pulling out(or pushing?) that squarish plastic piece that is lodged in the firewall itself. What is the best procedure to remove that thing from the firewall?
  • erik325i
    • Jan 2005
    • 3567
    You need to release the catch tabs that hold it into the firewall. There is one tab on the top, and one on the bottom. I have always been able to get them out by poking with screwdrivers. It's no fun at all.
    -Erik
    • Van Westervelt
      • 9365
      I just did this last week. Two options; channel locks, or vise grips. I put the vice grips on the plug about 2/3 of the way to the wall and clamped them down. That allowed me to push it 1/3 of the way through hence getting the tabs past the wall. Very easy. Took 30 seconds too :)
      • Van Westervelt
        • 9365
        What worked for ya?
        • Rocla
          • 922
          If you are replacing the whole cable, just put a flat screw driver on the plastic portiton and give it a good hit with hammer, the plastic will crack and the "holder" will come out.
          Current:
          BMW 320i 2d 2.0 m20 -88
          BMW 325i Cabriolet 2.5 m50 -88
          BMW 316i touring 1.6 m40 -90
          BMW 320i 4d 2,2 m54 -01
          • bmwdude
            • 268
            I became so frustrated that's what I ended up doing. Took a long 15 inch screwdriver, and one good hit with a hammer. It WILL come out! Just be careful to line up the screwdriver on the plastic piece. The firewall metal is thin, and you can easily make an unwanted hole. How do I know? Lets not go there...
            • Van Westervelt
              • 9365
              vice grips...
              • E30/M30
                • 224
                Just so you know what your dealing with, HTH
                • poplars
                  • Sep 2013
                  • 46
                  Thanks so much, this tip worked perfectly.
                  • GreasyE30
                    • Dec 2012
                    • 159
                    I've been needing to replace mine but have been unsure how to go about it. Thanks now I know what I'm getting from the junkyard next
                    2006 Dodge Magnum SRT8
                    1986 Slammed Shwarz ETA Coupé (DEAD)
                    2004 Slammed TSX A/T (Wifey's)
                    1963 Slammed ChevyII never ending project
                    1982 Suzuki GS1100GK CaféRacer
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Get a new cable. They are cheap and will be 100x smoother than a used cable.
                      • loloe13
                        • Jun 2014
                        • 4
                        I replaced my cable today, no kidding, damn it was hard getting that plug out of the firewall. I found it very hard to squeeze on the top tab especially.
                        What worked for me in the end, was rotating the whole plug by 90' (assuming the old cable will not be reused), with a grip plier. After that, squeezing the 2 tabs from both sides was much easier.
                        Gavin
                        • Sea Aych
                          • Apr 2013
                          • 767
                          Yeah, I ended up having to use extra long needlenose pliers, and I still broke the tabs
                          1988 Atlantisblau Euro/Japanese 325i Cabrio
                          1989 Schwartz 325i - now M50 powered! - now very dead
                          1998 Toyota 4Runner Limited - gone
                          My 17,000km Big NA National Parks trip!
                          • TimeMachinE30
                            • Jun 2014
                            • 3749
                            Whats the part number for the tab which is likely to break?
                            ACS S3 Build / Dinan 5 E34
                            • Reichart12
                              • Aug 2012
                              • 2165
                              It should be a one piece item, cable and tab all together. I think I bought one new for $20 or something cheap like that. 35411154285 from my records for the m20, not sure if different between year.
                              Instagram: Reichart12
