How to get this damn alternator bolt off??
  • kid8
    • Jul 2013
    • 312
    I've never taken the alternator apart to know. But can you tighten the stud to see if that stops it from spinning? If it's a pressed fit, obviously that wouldn't help, but if it can bottom out you might be able to tighten it up enough that after soaking it in pb blaster the nut would break free without loosening the stud again.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      looks like its a solid mounted stud so may need a new alt period
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Levy3Poop
        • Apr 2017
        • 536
        That sounds like it might be crazy enough to work. Also, it sounds like I *may* be able to try that before thursday. If I get the chance tomorrow, I'll give it a shot.
        Sent from my SM-N910V using Tapatalk
        • Levy3Poop
          • Apr 2017
          • 536
          Sheeiiiioot...well, I found less expensive ones on Rock Auto at least. What's the risk of an alternator with 10 fewer amps, just wondering.
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            Wont properly run things. Is yours an 80 or 90 amp?
            • Levy3Poop
              • Apr 2017
              • 536
              I'm not sure which one. I'd guess 90A just to be on the safe side.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Most are 80 amp iirc
                • E30-325iS
                  • Sep 2011
                  • 191
                  You could try cutting a slot across the tip of the bolt and use a flat blade screwdriver to hold it while you undo the nut.
                  • Levy3Poop
                    • Apr 2017
                    • 536
                    So cut a flat head into the end of the bolt, and use a normal wrench to undo it, right? That sounds like it could work
                    • LateFan
                      • May 2013
                      • 4434
                      I think he means use a dremel cutting wheel to cut a slot in the end of the stud, then use a big flat blade screwdriver to hold it from spinning. Good idea.
                      I don't know that you have room to grind flats for a wrench there.
                      • Levy3Poop
                        • Apr 2017
                        • 536
                        That's what I meant. Sorry for the vagueness in the reply. I just wonder about getting a screwdriver back there. I'll definitely give it a shot when I can though
                        • Echo30V
                          • Sep 2017
                          • 301
                          DING, ding, ding E30-325iS is the winner. Yes, yes, yes use the dremel to cut a slot into the end of the stud. Then use the biggest screw driver possible for leverage then try to back the nut off. PB blast the shit out of it first.
                          • Levy3Poop
                            • Apr 2017
                            • 536
                            Aye aye capitan!
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              Pull the alternator loose and turn it sideways while still in the car to get better access.
                              • Matt-B
                                The Waffler
                                • 3856
                                also dont quote real OEM for prices. also carful shopping at rock auto, they sometimes offer the cheapest shit available to them, i had a friend order a starter for his e36 and it came with all these chinese symbols in the case for 90-100$.
                                and for 120$ after the core was given back to me, i got a bosch unit
