Is Your fan squeaking?
  • ImmortalSoul219
    • Oct 2013
    • 8
    It's that time of year (winter) when the fans trying to blast heat. But the only thing Im getting is a ringing in my ears from the fans squeak.
    I have a 1985 e30 daily driver and two 1987 parts cars. All 3 fans squeak.
    I have searched and read of people talking about replacing the bushings. The motor works perfect just squeaks something awful. Why spend $200 or more on another motor?
    So I figured what do I have loose right?
    Went to the local hardware store. Picked up some bearings I thought would work from the measurements I took. Made a quick video of it for everyone to see the results. The bearings were only like $3 a piece. Took me about an hour i would say with filming as I went. I did pick up some oil impregnated brass bushings Im going to try on one of my other e30's.
    Its hard to make out in the video but the ball bearings are louder then the bushings (a good set that is) but way better then the bad squeaky bushings.
    So i have 2 more fan assemblies I was thinking of using oil infused bronze bushings instead of ball bearings.
  • ELVA164
    • 4861
    You could try oilite I suppose, worth a shot. You could also grease the current bushings. The low temperature is causing the squeak, just like all the other creaks and rattles that show up this time of year.
    Grr.
    • ImmortalSoul219
      • Oct 2013
      • 8
      I tried wd40 first. That last 1 day
      Then took the fan out an tried oiling it for a few days. That lasted a couple days.
      It’s been squeaking since the day I bought it. Finally had enough.
      • roguetoaster
        Biggus Tippus
        • 7829
        Nice one OP, sure beats $150 for an aftermarket unit or $550 for a BMW part.
        • Kershaw
          • 11822
          Nice job.
          My blower motor in the rallycross ix was completely frozen. I had a replacement, which I dropped and broke. Much anger later, I pb blaster the bearings on my old fan and slowly worked it back and forth until it spun free. Replacement bearings might be the ticket if it decides to seize up again.
          AWD > RWD
          • Todd Black 88
            • Oct 2007
            • 3449
            I had the same issue when I bought my m3.
            I pulled the assembly out and soaked the bushings in new engine oil. It sat on my bench for about a week.
            When I finally put it back in the car,.......it smoked something fierce. The smoke lasted for about 2minutes, and the motor was quiet ever since. It was in the car for about 8 years when I sold the car.
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • JIM1inWisconsin
              • Dec 2014
              • 116
              Does a new only really cost $500?
              • jeffnhiscars
                • Jun 2011
                • 6010
                Thats a nice repair. I just wish people would stop using WD as a lube.
                Alice the Time Capsule
                • roguetoaster
                  Biggus Tippus
                  • 7829
                  No, but that's what they sell them for.
                  • D.Martijn
                    • Sep 2016
                    • 1024
                    I bought a new one (for an AC E30) for 75€ although not original BMW, it does look great at first sight.
                    1990 325iX Touring - November 2018 R3V Car Of The Month
                    1980 Volkswagen Golf mk1 1.1
                    1974 BMW 2002 Touring
                    Instagram
                    • JIM1inWisconsin
                      • Dec 2014
                      • 116
                      fan
                      Bav Auto sells them for slightly over $200 and others can be had for less. I would buy new and avoid anything used. The install takes less than 30 minutes if you know what you're doing. The removal and install of the clip is a little tricky if you've never done this before.
                      • ImmortalSoul219
                        • Oct 2013
                        • 8
                        • DrJosh
                          • 2011
                          ACM (OEM) is $170.
                          I just ordered one and a new resistor because mine is squeaking, again. Now I'll never have to buy another.
                          Originally posted by Sonny
                          I am a meme for our community.
