Engine making awful noise after I did some heavy maintenance. IDK what to do
  • bSprague99
    • Apr 2017
    • 5
    Just replaced the timing belt, water pump, IM gasket, All gaskets around throttle body, replaced the timing tensioner, fixed a vac leak or two, and now my car makes like a crunchy/rattle noise when the throttle is lightly tapped, as well upon startup.
    Afraid to even move it out of the garage because it sounds so bad. When it's just idling, the engine seems fine, just when I give it throttle. Also, I gave it 30 percent throttle one time and it revved up and didn't stop. Had to turn off the engine. Seems like rattle coming from distributor area to below...
    Heres the video link to youtube:
    Thanks all
  • earthwormjim
    • Jul 2014
    • 434
    An engine can't continue to rev up unless it is being supplied with air. You still have a leak somewhere or your throttle body is sticking.
    Since you moved the throttle body, check the 90 degree hard lines that connect the idle control valve, and brake booster.
    Did you verify that timing is still correct when you replaced the timing belt?
    • jeffnhiscars
      • Jun 2011
      • 6011
      If you adjusted the valves they need to be redone and +1 on checking the belt
      Alice the Time Capsule
      • bSprague99
        • Apr 2017
        • 5
        The engine doesnt rev up anymore, just makes a bad noise still. Yes i verified timing. Dont think the car would start if the timing was off. Maybe the valves are off?
        • bSprague99
          • Apr 2017
          • 5
          I didn't touch the valves from before, is it possible to get them bad timing when rotating the engine manually?
          Also would the valves only do that on such light throttle? or was that just a side observation that you notcied from the video, that is something unrelated that needs to be done? http://www.r3vlimited.com/board/imag.../icon_razz.gif
          • e30davie
            • Apr 2016
            • 1788
            Nope.
            If it were me and i had an aweful noise after changing th etiming belt, id have it all appart again to double check everything.
            if you are out a tooth and your cam timing is wrong it can make the engine very sluggish and "not rev up" as you describe.
            your ignition timing is also driven by the cam, so if you are out a tooth your ignition timing will be wrong, can also make it not rev up.
            • earthwormjim
              • Jul 2014
              • 434
              What makes you think that? Engines will run with completely messed up timing. It would still run if one tooth off on the timing belt.
              Can you take off the accessory belt, you need to eliminate 1 by 1, your rotating assemblies.
              • superj
                • Feb 2006
                • 397
                I think its a fan or something hitting something else. fan, alt, something like that. check to make sure nothing is hitting a hose or something. I would say a shroud but you don't seem to have one
