car shutting off
  • robby41
    • Dec 2017
    • 88
    it was my 3 and 4 iron, definitely was very lucky
    • AndrewBird
      The Mad Scientist
      • 11898
      That wouldn't cause the symptoms your are describing. That wouldn't do anything at all actually...
      • robby41
        • Dec 2017
        • 88
        what would cause them then?
        • AndrewBird
          The Mad Scientist
          • 11898
          Any of the above suggestions are a possibility.
          • e30davie
            • Apr 2016
            • 1788
            Your description is extremely vague.
            heres a list of shit to check
            - Vacuum leaks - 99% of issues with m20 is vac leaks especially idle and dieing at low speed - they just cannot deal with aiir getting in around the MAF - there must be ZERO vac leaks for it to run properly. the smallest of leak has a huge effect on how the engine idles and runs at low throttle.
            - check errror codes in ecu - fix any sensors
            - fuel pressure regulator (unusual to die, but possible)
            - sparking plugs check the gap and condition
            -check if IAC is working, give it a good clean with carbon cleaner.
            - Did i mention vacuum leaks?
            • earthwormjim
              • Jul 2014
              • 434
              It would if it was shorting across the battery really quickly. I don't see how it would be repeatable though, you'd think eventually it would arc weld itself to the battery terminals or cause a fire.
              • efficient
                • Feb 2012
                • 3312
                Maybe your dme relay is going bad. My car would shut off while driving. It would start up again then turn off. Bought a new one and ot hasnt died since then
