Driveshaft vibration
  • Nick_e30
    • Mar 2016
    • 173
    I had hard vibration under accelration. I had the csb replaced and it has been fine for the past 2 weeks. But now I can feel it vibrating again. It's not nearly as hard or bad as it was before.
    does my driveshaft need to be balanced ?
    Sent from my SM-G950U using Tapatalk
  • Nick_e30
    • Mar 2016
    • 173
    I am m50nv swapped if that makes any difference
    • e30sh
      • Apr 2015
      • 618
      When my driveshaft started to fail, it would vibrate worse under hard load than normal driving. Turned out it was a u joint.
      If you have a factory assembled driveshaft, it will have white paint marks to show balanced / proper alignment between the front and back half's.
      • Metallated
        • Dec 2016
        • 1074
        Try using a hose clamp and adjusting it around the driveshaft. If it gets better in one place add more clamps until it is balanced.
        • e30sh
          • Apr 2015
          • 618
          My local driveshaft shop charges $49 to balance.
          • HerbE30
            • Nov 2015
            • 538
            I would look into this as well... And let me know if it helps! ;D
            20% Accurate
            Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
            • TobyB
              • 5297
              If it's vibrating under heavier load, look at u- joints, guibo, etc-
              off- balance usually is usually most noticeable at very light to no throttle at speed.
              t
