antifreeze instead of water
i dont think im running rich, and i dont give a fuck about my cat, i have no need for it
if anything i think im running lean
if you can tell me an easy way to make it run a little hotter than by all means tell me.
i have only the aux fan running at low, even when its 102 outside it barely goes past the 1/4 markYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
my gauge gets to the middle after 5 minutes and stays there maybe goes a little past and this happens only on a race circuit after 4-5 laps
but on race days i usually install my stuck open termostat
and as about water, there is now 100% water and so u think 50/50 will help?
i dont want the water pump to leakComment
And on Volgapowers case, do put the antifreeze ASAP.
Why do you think it's called antifreeze? As you know water will freeze at 0 deg C, if air temp is near to zero imagine what windfactor during drive will do to your raditator temp...
Frozen radiator and runnig engine will quite soon blow head gasket.Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01Comment
i think its called antyfreeze, because in my country it IS called so :)
ok i'll try to walk the shops find some...Comment
You also run the risk of getting rust in the system if you just run plain water.
1989 325iX
1995 540i
1986 325eS R.I.P.
1984 325e R.I.P.Comment
I know you don't care for my opinion but I'm going to give it to you anyways. That premixed stuff is lame. They market that stuff for people that don't know their supposed to add water to their antifreeze, ie: soccer moms and P.E. Teachers. Mine and many a techsworth.
sigpicComment
i dont think so, i can be sitting at a red light and the temp will climb up to about 1/2 way btw 1/4 and 1/2 and then ill start driving and itll stay around that temp for a while then pretty much all of the sudden itll drop down to 1/4. which i interpret to be the Tstat openingYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
i dont think so, i can be sitting at a red light and the temp will climb up to about 1/2 way btw 1/4 and 1/2 and then ill start driving and itll stay around that temp for a while then pretty much all of the sudden itll drop down to 1/4. which i interpret to be the Tstat openingComment
is there anyway to tell what temp tstat i have so i can order one of the sameYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
T-stats are cheap. Replace it, if it doesn't fix it keep your old one for a spare.
1989 325iX
1995 540i
1986 325eS R.I.P.
im not worried about the cost, i just dont wanna put the wrong temperature tstat inYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
