E30 Power Window Motor
  • InflatableWolf
    • Oct 2017
    • 13
    Passenger side power window motor seized up and I'm trying to replace it. Are the motors different from the left door to the right? It's a coupe.
    Probably a dumb question to ask, but I want to be sure.
  • tomstin
    • Mar 2015
    • 570
    Yes, different part numbers from left to right. Realoem should help you.
    2004 525i Manual - 1985 325E Coupe Manual
    • Zeemz
      • 485
      I might have a used right side motor I could sell you. Need to double check.
      1989 325is Lachssilber - Sold
      1990 325is Sterlingsilber - Current Project
      September 2018 Car of the Month: Zeemz
      Youtube Track & Autocross Videos
      • InflatableWolf
        • Oct 2017
        • 13
        No way to get a driver side motor to work?
        • Metallated
          • Dec 2016
          • 1074
          I have a used motor available as well.
          • Mpolito3355
            • Mar 2018
            • 82
            Mhm there is replace it :o
            51 33 1 370 839 part # for LEFT FRONT AND LEFT REAR or 51 33 1 386 987
            you have to double check those both.
            IDK if it matters about what year you have or not but you can always BMW and call parts and just ask them how much by your VIN and before you hang up just ask for a part number.
            but i would take the door panel off and double check its getting correct voltage.
            PERSON 1 - "It whispers to me at night...and convinces me i have to spend all my earnings on it...and buy all this stuff....to be cool...and be euro."
            PERSON 2 - "Oh your married too?? Oh you mean the car....yes ....yes i agree...:shock:"
            • superj
              • Feb 2006
              • 397
              I always took them apart and cleaned them and they worked. I just like to tinker with stuff when it quits so I learned you can do that.
              you can soak fuel pumps in carb cleaner over night and use a battery with some jumper wires to power them forward and backward and get them cleaned and working again, also. I have done that a bunch of times
              • InflatableWolf
                • Oct 2017
                • 13
                Update:
                Working with a guy to get the correct motor (he's sent me two wrong motors already)
                I did take it all apart, pull the regulator and motor. Motor is pretty much shot, got it to move again, but it takes dips in power but is getting the correct voltage so something in the motor is going out. The regulator also has a bad roller, like it's bent and won't turn, so possibly that might have put extra strain on the motor?
                Anyways, should have a motor and regulator coming soon LOL
                • Mpolito3355
                  • Mar 2018
                  • 82
                  Update:
                  Yea motors usually brake the regulators before the regulators brake the motor .....depending how bad it is of course...... Good luck with it hopefully you'll get the correct one .... you didn't have a part number on the old motor?????
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    FYI...the harness connector by the door hinge is famous for having bad connections that effect window operation
                    Alice the Time Capsule
                    • InflatableWolf
                      • Oct 2017
                      • 13
                      I used one of the motors that was sent to me to test the power, and it works fine. Only problem is it's the wrong side. Gotta love eBay LOL
