Preventing Dash Cracks, Once Wrapped?
  • HerbE30
    • Nov 2015
    • 538
    Been planning on getting into the dash game. Long story short, I would like to wrap my dash in Alcantara w/small amounts of Ti-Stitch accents. My main concern is what can I do to prevent the dash from fissuring once the fabric has covered? I have considered removing the entire top layer, foam included. But I worry about fitment and the OEM look if the half/quarter inch is missing.
    Any suggestions?
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • jeffnhiscars
    • Jun 2011
    • 6011
    If you remove the foam there's nothing left :)
    Alice the Time Capsule
    • Mwishlist
      • Jul 2013
      • 505
      I don’t know much about wraps but plan on covering mine next winter. I do know that from watching my wife’s crack free dash start to crack, they start small. I think it would take a long while for a new crack to be large enough to show through a wrap covering.
      Also would it be possible to put a very thin layer of padding between the dash and the wrap? Like when someone pads a steering wheel? a layer of padding it seems like that would give an extra layer that would keep cracks from showing through. No idea how that would affect wrapping it and adhesion etc.
      Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
      • HerbE30
        • Nov 2015
        • 538
        That's true. Still though, may take some R&D.
        I read an article that gave quite a bit of information regarding how the dash cracks. Apparently the most cracks occur during the transfer to cool. Essentially, when you leave the dash in the sunlight (under the magnifying power of the windshield) it will be fine, but once moved to the shade or cool, that is when it will crack(of course, typical expansion rules). The gentleman believes that covering them with cloth would stop this from occurring. But I don't know about the longevity and efficiency.
        I would hate to spend a few hundred dollars in fabric and hours of tedium, only to turn around and do it again.
        If I used padding I could run a diamond stitch. ;D
        Anyone have experience with the dash foam removed? What is the material?
        20% Accurate
        • dnguyen1963
          • Nov 2011
          • 2651
          Slightly off topic...to prevent the dash from cracking, one can apply suntan lotion to absorb the harmful UV rays.
          • digger
            • Nov 2005
            • 6198
            It's the temperature, thermal stresses contraction and expansion
            • HerbE30
              • Nov 2015
              • 538
              ;D I tried using tanning lotion to make it darker... Now it's just red?
              20% Accurate
              • IRON-E
                • 16548
                Here's what my brother is doing (auto upholstery pro) there's a process of filling the cracks. Then once that's prepped, it's left out in the sunlight for about 3 days, to make sure there are no other cracks arising. Cover the dash with a thin 1/8th inch of heavy duty foam and lay the dash cover on top.
                For future care of any material, make sure to use a heavy towel over the dash (like mentioned earlier) or some other type of material that repels UV rays.
                I'll be re-wrapping my dash in german vinyl in the future, to keep cost down.
                All upholstery materials have risen in price lately, so leather or alcantara would be out of the question as it's expensive and a pain to take care of when openly exposed to the sun.
                @IRON-E30 aka Edwin:D
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  Yep...and the UV rays have the most energy. If you let those rays absorbed by the dash then it gets hot and goes through expansion/contraction cycle leading to cracks eventually.
