Brake problem-dry left rear caliper?
  • 325e '87
    • May 2017
    • 503
    So I started to flush/bleed my brake fluid. Right rear went as expected, worked fluid out while feeding new in the reservoir.
    Left rear? I can’t get any fluid to come out of the bleed screw. It looks dry, like there hasn’t been fluid there for a while. My car stops nicely but I can believe it should be better but as I’ve driven the car I never ever felt like I was only using 3 wheels to stop.
    What’s going on and what’s the best way to tackle this, please? This is an ‘89 i
    My son has the 1987 325e, 2 door, 5speed
    I daily the 1989 325i, 4 door, 5speed
  • 101
    • Jul 2011
    • 764
    Remove the bleed screw entirely and try. Still no fluid?
    Next would be to loosen the rubber brake hose at the caliper and see if fluid is at least making it to the caliper. Note that you'll have to either remove the caliper from the carrier or loosen the connection between the hard line and the rubber hose to keep from twisting the rubber hose. Still no fluid?
    Keep working your way back to the "T" connector. One of the rubber hoses may have collapsed or perhaps there's a crushed hard line.
    Good luck!
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • uturn
      • Dec 2010
      • 998
      Take the bleeder screw off and poke a small drill bit or pick in there. Cover with rag and then pump the brakes. If nothing comes out then follow 101's recomendations.
      • 325e '87
        • May 2017
        • 503
        Thanks y’all. I removed the bleed screw completely and it’s dry as a bone in there, I picked down inside too, nothing.
        I will chase the line after I order some parts, if I can I just replace most things because I may end up breaking stuff in the process. I finished cleaning up and flushing the front too and I have the rotors off to knock off rust and paint (not the caliper surfaces).
        • jeffnhiscars
          • Jun 2011
          • 6010
          If it's bone dry the seals are probably bad so you'll want to rebuild both rear calipers
          Alice the Time Capsule
