M20 Head Bolt Socket
  • jeffnhiscars
    • Jun 2011
    • 6010
    I'm looking at sockets and I see the torx e12 but it doesn't say it's M20 specific
    Is this what everyone is using ?
    Alice the Time Capsule
  • Andre3127
    • Dec 2017
    • 291
    M20 head bolts are either 17mm or E14 e-torx.
    Budget E30 Parts - Used and Reconditioned parts for your BMW
    • jeffnhiscars
      • Jun 2011
      • 6010
      I hope no one still has 17mm head bolts.
      • 325e '87
        • May 2017
        • 503
        Both ours do. I’m preparing for a fresh head sometime this winter. Also, I haven’t read enough about the b27 to know if it’s an issue on the e cars. I’m sure the eta could benefit from a fresh head too, both engines are stock original with 200k miles on them.
        My son has the 1987 325e, 2 door, 5speed
        I daily the 1989 325i, 4 door, 5speed
        • jeffnhiscars
          • Jun 2011
          • 6010
          You realize the hex head bolts were recalled and that the torx tty bolts should either be swapped in or used when installing a head ?
          • 101
            • Jul 2011
            • 764
            It's an issue on all M20's.
            I can personally vouch for what happens when one of those hex heads decide to pop off and gets itself trapped under the camshaft. Goodbye head. Goodbye cam.
            You can perform a one at a time bolt replacement process and give yourself some peace of mind. We did that on two of the other cars with no ill effects.
            The BMW bolt set for around $30. Cheap insurance if you ask me. And a good excuse to adjust valves while the valve cover is off.
            101
            The E30 collection:
            1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
            1987 325is - Delphin / Black Sport (son #3's)
            1987 325i Convertible - Triple Black
            1989 325iX Coupe - Diamondschwarz / Black Comfort
            1990 325iX Coupe - Sterling Silver / Grey Sport
            1981 Fiat 124 Spider 2000 - Green / Tan
            1998 Volvo V70 GLT - White / Tan
            1998 Volvo S70 T5 manual - White / Taupe
            2001 Ford Windstar - Silver / Grey (parts hauler)
            2006 Lexus GX470 - White / Tan (tow rig)
            • Andre3127
              • Dec 2017
              • 291
              I've torn apart 5 m20's. All but one had hex head bolts.
              Hex head bolts hold just fine....until they don't.
              Sent from my XT1053 using Tapatalk
              • zaq123
                • Jul 2016
                • 1451
                I hope no one still uses head bolts on this engine. Studs are so worth it, regardless boosted or not. Torquing head bolts is nerve wrecking as they twist/bend/slide on washers etc etc....so not accurate
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Uh... what do you think the nuts on your studs are doing?
                  Torque to yield bolts are very accurate because you are not relying on a torque amount but rather an angle amount to determine fine tension on the bolt. Friction is a non-issue at this point.
