blower always powered
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    I was bleeding my car and had the blower fan switched to 4 and when i took it for a drive i kept it on high just incase. I turned off the car and the blower it still on, wtf mate? So what's the problem, is it a bad reisistor? if so where would it be located, if not what could be the problem? TIA
    • 34847
    I had the same problem, turned out to be a bad power reduction relay.
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      where would the power reduction relay be located?
      thanks
        • 34847
        sorry, I meant load reduction relay.
        it's in the fuse box. mine was in position K5, there's another one at K7. the positions are marked on the fuse box cover. somehow the relay got stuck open so there was always current going to my blower motor - probably because of some bad wiring instructions I got online. you can swap it with the O2 sensor heater relay or the fuel pump relay to see if that's your problem.
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          thaks nando ill check that! :)
