Throttle/Fuel issue
  • ezlnh8u
    • Feb 2012
    • 254
    Throttle/Fuel issue
    I have been noticing that when I come to a stop and I give the car a really quick push on the peddle, the car dies out. I have to ease the pedal to go from a stop. The car runs fine when I'm open throttle on the hwy. Some things I have checked. ICV, AFR, I swapped my Injector to 5.0 mustangs. No fuel leak or smell from the rails. All my lines look pretty solid and no cracks. Any suggestions?
  • roguetoaster
    Biggus Tippus
    • 7830
    Vacuum leak most likely, could be other things depending on what engine you have.
    • e30davie
      • Apr 2016
      • 1788
      " I swapped my Injector to 5.0 mustangs"
      why did you do this.
      • ezlnh8u
        • Feb 2012
        • 254
        I originally had a bad surgĂ­ng idle issue before. We replaced slot of things. The oem injectors were clogged with smuttand debree. The 5.0 I read are a good upgrade to the m20. My engine is from a 91 e30 325i.
        • e30davie
          • Apr 2016
          • 1788
          how many lb/min are the 5.0 ones compared to stock? And did it only start doing your symptoms when you put these "upgrades" in?
          Maybe its running pig rich when acceleration enrichment kicks in.
          • ezlnh8u
            • Feb 2012
            • 254
            I had the issue before with the oem injectors. I am almost thinking my engine harness is bad, we replaced the ecu twice also just to verify.
            • TobyB
              • 5296
              throttle position switch set correctly?
              t
              • ezlnh8u
                • Feb 2012
                • 254
                t
                I am not sure,any suggestions on how to check>? after testing, I did get noise on open throttle, but no noise on closed. Not sure if that means anything?
