Anyone made their own a/c hoses?
  • r-mm
    • Jun 2018
    • 203
    I did a full R134a conversion on my 89 325i last summer including compressor, expansion valve, drier, switch and condenser. I replaced only one hose I believe on account of the others were over a hundred dollars each, only available as BMW authentic parts. The system leaks out over a week or so and the dye/sniffer didn't help. I'll be pulling the motor soon and this will be the time to replace more lines.
    Always game to tool up, I see very nice Mastercool crimpers being sold for the price of one of the three hoses I need to make. Has anyone gone this route?
    Can the hard portions or the lines be re-used, with the appropriate crimps?
  • tomstin
    • Mar 2015
    • 560
    I cleaned out the metal hoses and took them too a local hydraulic hose shop and they replaced the rubber with barrier hose and crimped the ends for me. Cost me $85 and about 45 minutes of my time. I expected to drop them off and have to come back but they did it right then and there!
    2004 525i Manual - 1985 325E Coupe Manual
    • r-mm
      • Jun 2018
      • 203
      Good service....
      Can you remind me if there are rubber portions to the lines that run inside the car to and from the evaporator?
      • Supadave
        • 1006
        Free Shipping - Vintage Air E-Z Clip Refrigerant Hose Kits with qualifying orders of $109. Shop Air Conditioning Hoses and Lines at Summit Racing.
        I've been thinking of buying this kit.
        From website
        A "cool" way to plumb your ride for A/C--Vintage Air E-Z Clip refrigerant hose kits are easy and universal! The complete process from fabricating to crimping can be done by yourself in your own garage. This rugged, lightweight hose has a unique smaller diameter that allows tighter radius bends and a cleaner looking install. And, assembly of the hose and nickel-plated O-ring fittings is easy with the included E-Z cages and clips. Finally, a simpler, better way to route your air conditioning: Vintage Air E-Z Clip universal refrigerant hose kits.
        https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
        • nrubenstein
          • 3148
          Originally posted by r-mm
          Good service....
          Yes, there are rubber lines inside the car between the expansion valve and the firewall.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • nrubenstein
            • 3148
            FWIW, I have a crimp tool. It works well and I’ve used it a number of times. One issue that I have found is that many of the BMW hose line fittings end up being non-standard sizes, so you want to be sure that you have the right size hose and coupling for the job.
            • r-mm
              • Jun 2018
              • 203
              Thanks for flagging this - the tool I'm looking at has the size 6,8, 10, 12 Dies. I've yet to measure all the hoses on the E30 - do you think some fall outside the range that would be handled by these?
              https://www.amazon.com/MASTERCOOL-71...ustomerReviews
              • nrubenstein
                • 3148
                The standard hoses all appear to follow those sizes. I’ve run across some replacement hoses that were weird. Maybe a metric size?
                • tomstin
                  • Mar 2015
                  • 560
                  As I recall, one hose under the dash the shop could not help me with. I had to go to BMW for that hose.
                  • r-mm
                    • Jun 2018
                    • 203
                    Thanks guys. Think I'll go this route. Did you all buy hose and fittings from somewhere like this https://coldhose.com/hose-by-foot/st...rier-hose.html
                    I'm seeing barrier hose in the ~$2.50/foot range and fittings in the $5-10 each range.
                    • nrubenstein
                      • 3148
                      I’ve used cold hose before.
                      • r-mm
                        • Jun 2018
                        • 203
                        Are the BMW hoses SAE / Inch threading?
                        Did you use Alum or Steel fittings?
                        For instance
                        Alum, SAE threading https://coldhose.com/fittings/oring/...tting-902.html
                        Steel, SAE threading https://coldhose.com/fittings/oring/...tting-900.html
                        • jeffnhiscars
                          • Jun 2011
                          • 6010
                          I sent the 2 hoses above the glove box to a hydraulic shop for upgrading to barrier. $75 included return shipping. You just have to find the right shop
                          Alice the Time Capsule
                          • r-mm
                            • Jun 2018
                            • 203
                            Im going full DIY here. Crimper will be here
                            Tomorrow. Just gotta figure the fittings out, will likely buy more than I need.
                            • r-mm
                              • Jun 2018
                              • 203
                              Could use someone's help figuring out what the name of the fitting is where a hose connects to a hard line.
                              A photo of the hard lines stripped of the hoses would help too. Are these barbed? Is this just a ferrule such as: https://coldhose.com/specialty-fitti...ividually.html
