Fuel displacement blocks
  • OriginalSterm
    • 34
    I have a late 325 tank in what is being raced as a 318is. The rules state I can't run the bigger tank without being bumped to a higher class. I am allowed to add displacement blocks (or balls) but which side of the tank makes the most sense? More of driver's side? Passenger side? Split them up evenly?
  • squidrope
    • Dec 2012
    • 291
    Not sure how you could get them on the drivers side? GL and looking forward to what you did.
    • OriginalSterm
      • 34
      Isn't there access through the sending unit hole?
      • TobyB
        • 5280
        Yup. 42 ping- pong balls and off you go.
        Or slug the bottom of the driver's side with a 5 lb dead blow until it's
        12 smaller.
        t
        • OriginalSterm
          • 34
          12 smaller.
          t
          Denting the tank is the easiest option and my first choice, except the rules clearly state I can't do that. So ping pong balls (or similar) is probably the way to go. Do I put them all of the driver's side away from the pump? Do I split them up evenly?
          • TobyB
            • 5280
            Boy, I would put them on the driver's side, for sure.
            DO make sure they won't dissolve in fuel! THAT
            would make a holy mess!
            I'm hampered by having taken apart too many other cars
            recently- isn't the late tank a 'saddle' tank, with a connected
            top? If it is, they're just going to float around up on top
            anyway, so it won't matter.
            t
            • OriginalSterm
              • 34
              I'm much more familiar with the early 325 tank and the crossover tube. I thought the late style use a syphon to pull fuel over?
