Surging Idle after Rebuild
  • Plumberpat
    • Oct 2018
    • 12
    Here’s the details: 1990 (10/89) 325i Convertible
    Just finished refreshing the motor: rebuilt head w/ 272 cam & HD rockers etc, all new belts, wires, cap&rotor - the works in other words. Get it all back together and it idles like total crap. Surges from 500-650 constantly. Once you get the RPMs up its better.
    Get it smoke tested and find a bunch of leaks - bitch tube etc. Fixed those and it idles better but not great. It idles like a 1/4 mile drag car - lopey. Mechanic thinks it’s fuel (car has 208k on it). So I swap out the original injectors for some new Bosch units and swap the TPS. Still no love.
    So I start testing the ICV (three wire). Voltage and resistance check out and I double checked the TPS as well - both good. Bentley says the ICV should be partially open with a warm engine and the key on. Mine snaps closed as soon as the key is turned to the on position.
    Is this the issue?
    Thx, Pat
  • jbontke
    • Mar 2019
    • 449
    Are lifters are adjusted properly??
    • ForcedFirebird
      • Feb 2007
      • 8300
      Surging is a sure sign of vacuum leaks post-AFM on these cars.
      john@m20guru.com
      Links:
      • Plumberpat
        • Oct 2018
        • 12
        Smoke tested and fixed the leaks. After running for a few days the surging is gone but it’s a really lumpy 700ish rpm idle. I didn’t think a 272 cam would make it that bad. It’s stock (for the moment) other than the cam. Is this something that would be cured by a ssquid chip? Or should it idle better even with the 272?
        • digger
          • Nov 2005
          • 6143
          Chip to bump up idle speed
