CF sunroof fitment
  • Digitalwave
    is a poseur
    • 6299
    CF sunroof fitment
    Alright, well I installed my sunroof today and it fits like balls. I have a used two piece gasket and apparently its thinner than the one the previous owner of the sunroof had because there are gaps between my seals and the roof of the car.
    Ryan's car seemed to have a much thicker, one piece gasket. Is this what I should be buying for my car?
    Here are some of my fitment:
    RISING EDGE
  • James Crivellone
    Head Janitor
    • 6305
    I personally used the 1 piece gasket and it fit a bit better then the 2 piece...yet everybody recommends the 2 piece one, no idea as to why.
    • Digitalwave
      is a poseur
      • 6299
      How much did it cost you James?
      RISING EDGE
      • James Crivellone
        Head Janitor
        • 6305
        $92.70
        • Jand3rson
          • 37587
          TJ, your sunroof looks tight as hell.
          Your sig hurts my head.
          • LINUS
            • 2422
            So what's the deal with the 1-piece unit? I got the same roof, so fitiment would be identical. Mine came with the 2-piece glued to it, but there's a 1/4" gap on each side at the seams. I like the idea of a 1-piece a lot better. Any reason I can't use it despite my original roof panel in the car wearing a 2-piece seal?
            -B
            It's not how you handle the good times, but the faith you keep in the bad that defines you.
            • AlpineIS
              • 161
              I don't understand why BMW makes a 1 piece and a 2 piece gasket available. Is one better than the other? If a 2 piece is used should the shorter go up front, back? Does it matter?
              • Digitalwave
                is a poseur
                • 6299
                The shorter is supposedly the front on the 2 piece.
                RISING EDGE
                • Digitalwave
                  is a poseur
                  • 6299
                  My front seats got a soapy bath when I washed my car today :(
                  RISING EDGE
                  • LINUS
                    • 2422
                    That sells the 1-piece unit for me right there.
                    • Digitalwave
                      is a poseur
                      • 6299
                      How so?
                      RISING EDGE
                      • LINUS
                        • 2422
                        Aren't you running the 2 piece? I have one on my panel, and there's 1/4" gaps on both seams. I realize the water isn't 100% sealed by this gasket, but you have to at least try. Unless your soapy seats were caused by another reason - context of conversation led me to think you blamed the gasket.
                        • Digitalwave
                          is a poseur
                          • 6299
                          The gap isn't between the 2 gaskets, its between any given part any the roof itself.
                          RISING EDGE
                          • LINUS
                            • 2422
                            O.K. - would having the supposedly thicker 1 piece gasket solve that?
                            • Digitalwave
                              is a poseur
                              • 6299
                              Perhaps. I don't know anybody with the gasket that has confirmed if its thicker or not though.
                              RISING EDGE
