Engine cutting out at high RPMs, feels sluggish.
  • O 16581 72452 5
    • 1066
    It's an 87 325i, i replaced the fuel filter and it seemed to run better, thought it was back to it's old self, later in the day i took it up again and it felt like it was "running out of steam" and it cuts out like a rev limiter around 6k. It was intermittant before, but now it's more regular. I tried a top speed run at a safe location (not a public road) and only reached around 125.
    I'm thinking it's time to get a cap, rotor, wires, and plugs, but they're pricey for these cars, i'm looking at $200 for everything. I don't mind putting that into my car by any means, but if there's another reason to look at that's less, i'd like to look into it before i do that. No CEL.
    On another note, is there a place other than AutoZone/Advance to look for maintaince parts?
  • Mike325
    • Mar 2006
    • 3685
    There are a lot of places for the maintaince stuff like bma, bavauto and the euro depot.
    Originally posted by Kershaw
    • O 16581 72452 5
      • 1066
      So is this "General Technical"? :|
      IMO they're so similar it should be one forum.
      • AdamF 88iS
        • 2051
        I had a similar situation on my car. It turned out to be an AFM problem.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • golde30
          • 11464
          cuts out @ about 6k, goes to 125mph...dude, those are the limits on an m20b25, set by the ECU programming. if u want more out of the motor, you need to purchase an aftermarket chip for your ECU. they will typically give you redline @ 6.9K and top speed about 145...also, you will need to run 91+ octane at all times with a chip.
          IG: @Baye30
          • O 16581 72452 5
            • 1066
            Uh, no my rev limiter until recently was a little over 6.5k, now it's cutting out before the redline, according to the owner's manual, the top speed is supposed to be 134. Occasionally it goes past that cutting out and hits the ECU's rev limit, but something isn't right.
            • AdamF 88iS
              • 2051
              6500rpm is stock for that car.
              Adam Fogg- '88 M3
              • O 16581 72452 5
                • 1066
                Ran okay a few pulls today, one was a smooth pull, another it hesistated a little at 6k, another it cut out completely at 6, another it cut out and slowly climbed. Gahhhh.
                • Kruzen
                  • Mar 2004
                  • 5603
                  Hey i have an idea.
                  Read the thread dumbass
                  Who doesn't love a little BBQ?
                  Griot's Garage at a Deep Discount
                    • 34839
                    stock B25 rev limit is 6250
                    top speed limiters are only on late model cars
                    and your problem really sounds like a bad AFM.
                    • O 16581 72452 5
                      • 1066
                      Originally posted by Kruzen
                      Hey i have an idea.
                      And it says what? This isn't the way my car was acting when i bought it, it pulled strong and hit rev limiter after 6.5k.
