My engine randomly shut off on the highway.
  • O 16581 72452 5
    • 1066
    I don't know WTF this was about, i was cruising along and suddenly my tach dropped to 0, no dummy lights or anything until i disengaged the clutch and the engine came to a halt, then everything in the dash turned on, engaged the clutch and the lights again went off. Did this a few times with the same results until just as random as it shut off, it kicked back on and i was on my way...
  • Mastrcruse
    • Sep 2005
    • 5340
    We had the same problem with my brothers E. We had it inspected and ours happen to be the Idle control valve. The little screw would screw itself in the unscrew itself, lean/rich, lean/rich. I remember going on the high pushing in the clutch, everything turned off, let the clutch out a boom started itself back up and did that A LOT! Fixed it and symptoms are all gone.
    • O 16581 72452 5
      • 1066
      Heh, that's crazy it would do that, i'll look into a new IACV because the engine does what you're describing.
      • moatilliatta
        • 6144
        mine had that happen one weekend and then went away. i thought it was fuel pump or fuel pump relay. but it came back on after like 7 min.... it was quite strange.
        @Zakspeed_US
        • O 16581 72452 5
          • 1066
          Seems to me it'd be ignition related since the tach works from an ignition signal. It didn't matter how high the engine was spinning (disengaging the clutch in different gears), the tach didn't move.
          • James Crivellone
            Head Janitor
            • 6304
            In order of possible failure
            Bad Main Relay
            Bad Speed Ref Sensor
            Bad ECU
            1 is the most common
            • O 16581 72452 5
              • 1066
              Bad Main Relay
              Bad ECU
              I had a car with a bad main relay and it acted differently, it wouldn't randomly shut off, it'd randomly not start or start, but it wasn't a BMW. Would resoldering it take care of the problem?
              • moatilliatta
                • 6144
                mine has acted fine since then... i also thought it could have been main relay.. i swapped them out and still had a problem.
                @Zakspeed_US
                • emi325i
                  • Oct 2006
                  • 356
                  check the injector harness, too. make sure the connector's all the way in ,and twist the lock until it clicks.
                  • Mike325
                    • Mar 2006
                    • 3685
                    My car did this and it was the main relay.
                    Originally posted by Kershaw
                    • O 16581 72452 5
                      • 1066
                      I can try resoldering it to see if it helps i 'spose, it's free.
                      • moatilliatta
                        • 6144
                        resoldering what?
                        @Zakspeed_US
                        • O 16581 72452 5
                          • 1066
                          Originally posted by moatilliatta
                          resoldering what?
                          The main relay consists of many solders that over time can crack (may not be visable) sometimes they don't get a good contact and resoldering them solves this. I don't know if it's a problem in these cars, but other cars i've had have had this problem, resoldering took care of it.
